SubForums: Events Scanners
Old 08-13-2013, 01:05 AM   #11
Boater
Default Re: Wheel bolts
My alloys also used a bolt with 60 degree taper under the head, whilst the steel wheels use a bolt which is rounded under the head - you should check length AND fitment, although I'm sure it is the alloys that damage rather than the steel ones if you use the wrong type of bolt.
Also be aware that alloys might have spacers fitted to correct for offset, you should remove them with the wheel before fitting a steel spare.
But yes, if you have factory wheels and spare they will all be the same.
Old 08-14-2013, 02:46 AM   #12
John484
'06 140 2500 SHC
Ok thanks men!
'06 140 SHC
John484 is offline   Reply With Quote
Old 01-07-2016, 03:03 PM   #13
ECU
ECU's Avatar
Can someone post the sizes? More than just longer/shorter would help. And the taper would be helpful. I just picked up some alloy wheels, need to get the bolts.
Old 01-08-2016, 02:11 PM   #14
This just occurred to me. Nobody knows who might be changing the tire. Just knowing about this problem may not be enough.
Those who have alloy wheels and long lug bolts would be wise to include a large print warning about the bolts in with jack tools. Even better would be to cable tie a weatherproof warning to the spare tire wheel. I would thread the cable tie right through one of the lug holes. One would hope that roadside assistance would know about the difference, but it would be best not left to chance.
The spare is accessible enough that a laminated yellow or red note can be added without dropping the spare out of the holder.
Inspector (02-18-2018), sailquik (09-22-2019)
Old 01-08-2016, 02:39 PM   #15
ECU
ECU's Avatar
It is important. How about posting the sizes/tapers of the various bolts. Thanks.
I currently have C&S rims with a Steel spare. I want to swap with Alloy and want to know what to look for in lug bolts.
Old 01-08-2016, 08:02 PM   #16
derekhski
derekhski's Avatar
Here is a link to Europarts I bet if you call them, they may disclose the size?
http://europarts-sd.com/lugbolt-stee...2-2006-1-1.asp
and as pulled from a UK based Ebay add, 05104018AA is the part number in the Parts list I have access to.
MERCEDES SPRINTER Wheel Screw 09806 Febi 05104018AA 5104018AA 6384010171 New
Brand Febi
Part Number 09806
Weight [kg] 0.11 kg
Fitting Position Rear Axle, Front Axle
Outer Thread [mm] M14x1.5mm
Thread Length [mm] 22.5mm
Length [mm] 74mm
Spanner Size 19
Bolt Head/Nut Design Male Hex
Surface Dacrometised
Quality/ Grade 10.9
OEM references
CHRYSLER 05104018AA
CHRYSLER 5104018AA
MERCEDES-BENZ 638 401 01 71
2002 118" Passenger 240,000
upgraded to 16" wheels
(changing to Falken WildPeak Winter 2018),
Also Running LT215/85R16 Continental (they fit)
Sumo Springs F/R, Monroe F/R,
Qpax Light Bar
Daughter calls it the "Daddy Bus"
(was RedDino's at some point)
Portland Oregon USA
derekhski is offline   Reply With Quote
The Following User Says Thank You to derekhski For This Useful Post:
ECU (01-09-2016)
Old 01-09-2016, 07:31 PM   #17
PLOUGHLIN
It is in the MB manual for my Sprinter (UK) Is it not in the US manual?
Peter
PLOUGHLIN is offline   Reply With Quote
Old 01-09-2016, 07:38 PM   #18
PLOUGHLIN
Just checked a 2011 US manual, Page 232 shows the bolt difference.
Peter
Old 01-10-2016, 12:03 AM   #19
sailquik
sailquik's Avatar
ECU,
Did you just get the factory alloy rims with 5 lug bolts, or something else?
The longer lug bolts made specifically for the factory alloy rims may be quite different than what you
would need for aftermarket alloy wheels.
Old 01-10-2016, 12:32 AM   #20
ECU
ECU's Avatar
ECU,
That is why just the pictures don't quite work for me. Currently, I have aftermarkets with a steel spare. I have appropriate lugs for this setup. But I picked up some alloys and would like to know if the aftermarket lugs would work or not with the factory wheels.
The Following User Says Thank You to ECU For This Useful Post:
