Go Back   Sprinter-Forum > General Forums > Sprinter Talk > Scanners
Old 11-26-2018, 06:16 PM   #181
Default Re: iCarSoft MB II users group discussion thread
Originally Posted by sethlp View Post
I think I'm mistaking chassis for wheel base. I have a 140 wheel base. Is that different than a 903 906?
I'm not finding my answer in the wiki
The "903" and "906" are the MB numbers for the body style of the Sprinters.
The wheelbase doesn't really factor into that.
(after all, 140 is in *inches*, and MB actually uses (surprise!) metric: 3550 mm )
(my 118" wheelbase is 3000 mm in MB-speak)
If you have your Sprinter's datacard, look at the *other* VIN (or VID) number... it will have the "903" as the 4th thru 6th characters.
We're also known as "316" ... you'll see that number used by many UK and Australian members when they're posting about their Sprinters). The "3" means "Sprinter" 3 tonne (see Cheyenne's note).
The "16" part of that is our engine size (in horsepower, rounded to the nearest 10, and then dropping the trailing zero) ...
I've also seen us as "VA", with the NCV3 being "VB"
p.s. to get your MB datacard (what they built into *your* Sprinter), go here: http://carinfo.kiev.ua/cars/vin/mercedes/vin_check
..and type in your VIN ... you can then screen-scrape the results instead of paying for a PDF copy.
DesertAdventures (12-06-2018)
Old 11-26-2018, 06:57 PM   #182
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
The "16" part of that is our engine size (in horsepower, rounded to the nearest 10, and then dropped.
Not quite right Dick,
The 3 means a nominal 3 Tonnes GVW, ie between 3,000 and 3,999 kg Gross Vehicle Weight.
My 313 CDI has a GVW of 3,800 kg but a 416 CDi would likely have a GVW of 4,200 kg or 4,500 kg.
Keith.
36,000 miles from New
The Following 2 Users Say Thank You to Cheyenne For This Useful Post:
autostaretx (11-26-2018), DesertAdventures (12-06-2018)
Old 12-29-2018, 11:11 PM   #183
JSL
Hi Ya'll,
I am a new-to-me Sprinter owner and have been reading through this thread - just got my icarsoft in the mail, but it's not connecting to the ECU. It will talk to parts of the van - I see it lighting up some stuff on the dash - but not the ECU. It says "NO OBD" and reading a "CAN communication error" with the ECU, the brake system and the transmission. It's running version 11.11 - from what I'm reading, it seems like I do not need to update for it to work correctly, but just looking for verification on that.
It looks as if a couple other folks have had this problem, but for most folks seems like it's easy to plug-and-go... desperately need to check fuel rail pressure.
Any advice for me?
JSL is offline   Reply With Quote
Old 12-29-2018, 11:27 PM   #184
DUTCH VanAtlanta
Curmudgeon
DUTCH VanAtlanta's Avatar
Begs the question if anyone has used the iCarSoft MB V2.0? That is supposed to be the updated version of the MB II scanner with a faster process speed and Data Print.
DUTCH VanAtlanta is offline   Reply With Quote
Old 12-29-2018, 11:43 PM   #185
Brokecanadian
2005 Cargo 2500 SHC NA
Originally Posted by JSL View Post
Hi Ya'll,
Any advice for me?
I think I covered it in my huge post awhile back.... What's missing is your year of Van, I had no luck on later models other than resetting the trouble codes, past 2013
I also think the recent ecu reflash recall has screwed up some people. I avoided all recalls
Brokecanadian is offline   Reply With Quote
Old 12-30-2018, 01:03 AM   #186
mountainhick
mountainhick's Avatar
Hi Ya'll,
Any advice for me?
What is your year and model Sprinter?
I had the same with 11.11 for my 2006 T1N. You have to download the 11.20 update. You need the correct update version for your model scanner. It is a little non intuitive on their website. Across the top of this web page select the scanner model you have in order to go to the correct download. https://www.icarsoft.com/Page/103.html
I also found this site to be a great help figuring out where to find which scans for various needs: https://sprinter-camper.com/icarsoft...ntrol-modules/
2006 140" High Roof T1N OM647
Cargo van turned camper
mountainhick is offline   Reply With Quote
The Following User Says Thank You to mountainhick For This Useful Post:
autostaretx (12-30-2018)
Old 12-30-2018, 11:32 PM   #187
JSL
Hey ya'll, thanks for the posts -- I wasn't being alerted, otherwise would have checked faster.
I have a 2002 cargo van, 158, high top. 903. Not sure how many ways I need to identify it. ha.
I did the update, no joy.
It will read things like RPMs, coolant temp, speed, etc. but won't recognize the protocol (in the beginning) and it can't see the OBD. I can't start the van (doesn't run - hence why I need the scanner) so the only thing I haven't been able to do is play with the tool while the van is running.
I have checked voltage and ground in the port. TBH the port looks a little beat-up and I'm wondering if anyone knows how to diagnose a bad OBD port? I was told that I could find diagnostics for the OBD port in the manual, but haven't come across it.
Will also check out the links - thanks ya'll
Old 12-31-2018, 08:58 PM   #188
mountainhick
I can't tell if you read through the website I provided. https://sprinter-camper.com/icarsoft...ntrol-modules/
If you don't pull up the right version of iCarSoft in the menu and then correct vehicle section, you won't find what you need.
e.g. if I remember clearly, to access ECM engine data, you need to use 11.20, then 960.6 or 901.6-etc multiple model number listing then look at CDI common rail.
Otherwise, it does sound potentially like a connectivity problem.
Old 12-31-2018, 10:01 PM   #189
JSL
@ Mountainhick - yes sorry, I did look at that website sorry. It was mostly info I already knew, so I didn't think to mention it - though I appreciate it.
I ended up sending back the icarsoft and am going to try the Autel. Bummer. Guess I'll be switching to the other troubleshooting thread :)
The Following User Says Thank You to JSL For This Useful Post:
mountainhick (01-01-2019)
Old 01-14-2019, 09:43 PM   #190
sprintertjrll
I have an 05 Dodge sprinter and am looking for a quality scanner that will read injector correction values, o2 sensor and turn off injectors. Will this scanner do this?
sprintertjrll is offline   Reply With Quote
The Following User Says Thank You to sprintertjrll For This Useful Post:
Lorryist (10-06-2019)
