Old 01-10-2019, 04:57 PM   #121
Luc
Default Re: So here goes my Van Gogh project!!
Exactly! Just continuity.
This specific model is DC only, but there are 120V variations.
I decided to do it myself after seing that exact same add!
From what I’ve read, it’s better not to play with compressor speed for a few reasons (wear, duty cycle, power draw)
These compressors are really widespread, so You have to imagine that the manufacturer tweeks the speed just right with the resistor, for each fridge size application.
2006 T1N, 158" WB, Hight top, cargo van
Slowly but surely getting transformed into my first camper van
Luc is offline   Reply With Quote
The Following User Says Thank You to Luc For This Useful Post:
wankel7 (01-10-2019)
Old 01-21-2019, 02:46 AM   #122
Woodythesprinter
Woodythesprinter's Avatar
Je suis tombé par hasard sur ton thread. Tres beau projet et content que tu l'ai gardé finalement, Tres bien planifié
Woodythesprinter is offline   Reply With Quote
The Following 2 Users Say Thank You to Woodythesprinter For This Useful Post:
HarryN (01-21-2019), Luc (01-21-2019)
Old 01-21-2019, 04:03 AM   #123
slem
slem's Avatar
WHAT?:
slem is offline   Reply With Quote
Old 01-21-2019, 06:39 AM   #124
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Originally Posted by slem View Post
WHAT?:
Courtesy of Google translate:
"I stumbled upon your thread. Very nice project and glad you finally kept it, very well planned"
35,000 miles from New
The Following User Says Thank You to Cheyenne For This Useful Post:
slem (01-22-2019)
Old 01-22-2019, 09:37 PM   #125
VinceP
2005 158" High Roof Pass.
That's because us frenchies like to write in our language sometimes... Sorry for that!
Rusty but Happy Sprinter in Montréal
VinceP is offline   Reply With Quote
Old 01-23-2019, 02:10 PM   #126
Luc
I saw a thread regarding showers today, so I thought I could share what I have come up with
So my shower system is quite simple, it's a waterproof vinyl textile (heavy weight) "tub" that measures 24" wide x 36" long x 24" high (makes it quite comfortable to sit down or kneel in the tub).
All along the upper edge, there is a sewn loop that allows to insert a 3/4" PVC pipe that makes up the frame of the tub. The corners are 3-way corner fittings and then 4 vertical pipes to hold it up. Nothing is glued on the pipes, it's just a dry fit to allow break-down.
I just heat up some water on the stove, and mix with cold water in the Helio Nemo shower. Pump it up and just for it. I can usally shower with 1 Gallon of water. This is then easily dumped outside, or scooped up with a bowl and dumped in my sink when I'm in the city.
I just saw a picture on another thread where they make a drain that goes through the kick plate of the sliding door step. I think I'll make something like this and just add a "through-hull" fitting in the bottom of my tub and it will make draining easier.
When I'm finished, this thing rolls-up with the pipes and all, to an 8" diameter roll x 36".
I would do the same thing again if I had to.
The Following 3 Users Say Thank You to Luc For This Useful Post:
ranchworld (01-23-2019), slem (01-24-2019), TamagoVan (01-23-2019)
Old 01-23-2019, 05:35 PM   #127
TamagoVan
2016 144 High Roof
TamagoVan's Avatar
Very nice, Luc! Can I ask if you made or bought this "tub"?
TamagoVan is offline   Reply With Quote
Old 01-23-2019, 05:44 PM   #128
Luc
I had a local shop fabricate it for me. I just brought him the PVC pipe frame. Seams are sewn and glued. It's a supplier that makes medical lifting apparatus, and awnings and stuff like that.
TamagoVan (01-24-2019)
Old 02-26-2019, 04:17 AM   #129
mtlsimon
Sent you a private message!
mtlsimon is offline   Reply With Quote
The Following User Says Thank You to mtlsimon For This Useful Post:
Luc (02-26-2019)
Old 05-15-2019, 03:50 PM   #130
Luc
I just blew my engine and got it changed. The story is in this thread:
https://sprinter-source.com/forum/sh...441#post768441
