Old 08-31-2019, 04:35 AM   #241
royce
Default Re: New member with new van
Did a little rat killing today,while waiting on shower and countertop fabrication to get here.
Epoxied a couple plugs in the stock floor mounting holes and also cleaned up the wiring that runs through the upper cabinets with some split loom.
I had originally thought I would make aluminum covers, but this split loom was quick and cheap.
I don't care for the split loom, now that it is in and will probably form some aluminum covers at some point.
Looks like I won't see the countertop and shower fabrication till next week.
Royce
royce is offline   Reply With Quote
The Following User Says Thank You to royce For This Useful Post:
Surveillance Van (08-31-2019)
Old 08-31-2019, 04:38 AM   #242
royce
Here's the split loom
Royce
The Following 2 Users Say Thank You to royce For This Useful Post:
SD26 (08-31-2019), Surveillance Van (08-31-2019)
Old 09-01-2019, 06:35 AM   #243
royce
Got the table tops, drawer fronts and cabinet doors sanded and the first coat of varnish on one side today.
Royce
Surveillance Van (09-01-2019)
Old 09-01-2019, 12:01 PM   #244
SD26
2012 NCV3 3500
That's varnish over carbon, Royce?
SD26
2012 Sprinter 3500 170EXT
2004 Sprinter 2500 158, totaled by deer 5-2019
SD26 is offline   Reply With Quote
Old 09-01-2019, 08:49 PM   #245
royce
Yes, carbon fiber.
I used the word varnish loosely, it is actually clear urethane to protect the epoxy from UV exposure and give a final finish.
Royce
The Following 5 Users Say Thank You to royce For This Useful Post:
HighPockets (09-02-2019), sassyinpink (09-02-2019), SD26 (09-02-2019), Surveillance Van (09-01-2019), vannoob (09-01-2019)
Old 09-02-2019, 04:53 AM   #246
sassyinpink
Originally Posted by royce View Post
Yes, carbon fiber.
Royce
that will protect from the weathers? usually how long does a new fresh coat is needed to protect the van again?
sassyinpink is offline   Reply With Quote
Old 09-02-2019, 05:43 AM   #247
royce
The epoxy protects from weather, the clear coat protects the epoxy from UV damage.
On the inside of the van where these cabinets are located, the clear coat should last for many moons.
The Following 3 Users Say Thank You to royce For This Useful Post:
HighPockets (09-03-2019), sassyinpink (09-03-2019), Surveillance Van (09-02-2019)
Old 09-03-2019, 04:21 AM   #248
sassyinpink
oh icic. thanks thanks for sharing. trying to learn more on maintenance and repairs
The Following User Says Thank You to sassyinpink For This Useful Post:
royce (09-03-2019)
Old 09-04-2019, 04:50 AM   #249
royce
Got the upper cabinet doors hung for the last time and the strike plates whittled to final fit.
Looks pretty good with the satin finish, even with the warts, pimples, skeeters and dust.
Royce
Surveillance Van (09-04-2019), vannoob (09-04-2019)
Old 09-06-2019, 05:29 AM   #250
royce
Picked up the shower pan fabrication today.
It is a two piece design with one piece being permanently bolted to the floor with the drain.
The domestic water tank will nest in the rear portion of it
Royce
The Following 4 Users Say Thank You to royce For This Useful Post:
Mickyfin (09-15-2019), SD26 (09-06-2019), Surveillance Van (09-06-2019), vannoob (09-06-2019)
