Closed Thread
Old 08-25-2017, 03:12 AM   #21
SSMaui
Fleet Chief
Default Re: DEF Adblue Diesel Exhaust Fluid 10 Starts
That Xentry scan page looks fake as hell.
Here's what it should look like.
I wouldn't even trust that print out! But if I were to only go with that, I'd first replace the NOx1 and teach in the SCR cats, SCR temp sensor, DEF injection nozzle and set up the "Test of Exhaust Aftertreatment" (Xentry only) and send you out to drive for 30-45 minutes. (not 100 miles)
The test makes everything adapt quicker to get to the root cause. New codes after the test help pinpoint the real problem.
Just FYI, 4 of those codes are from having the airbox removed when scanning.
Please post the results form your new diagnosis!
Fleet Service Manager
73 Sprinter 2500 170" WB (2012+)
6 Sprinter 3500 (2008)
5 R350
2 GL350
SSMaui is offline
Old 08-25-2017, 03:23 AM   #22
SSMaui
Fleet Chief
Originally Posted by avanti View Post
Dennis,
Can you elaborate on this? My clone Xentry stuff appears to be able to do everything except resetting a countdown (it CAN add 5 starts to it, though--I don't know how often). It certainly can do live monitoring of all sensors as far as I can see. All of the adaptations appear to be available as well. I have been following your advice about not messing with anything that I don't fully understand, so I don't know if the adaptations would actually work, but they sure look like they would. Am I in for a surprise if I ever attempt something deep?
One of the Techs on a different island has it. While it says it will do things, it actually can't once you delve into it. It crashes a lot when you try.
I do not think it will actually SCN code which is why it can only add the starts (generally once) since that doesn't require it.
I would be leary of it for anything other than reading codes and watching actual values.
5 R350
2 GL350
SSMaui is offline
The Following 2 Users Say Thank You to SSMaui For This Useful Post:
Bobnoxious (08-25-2017), lindenengineering (08-25-2017)
Old 08-25-2017, 03:32 AM   #23
lindenengineering
Yes actually we have formulated & developed by "doing" a whole test plan and driving procedure in our shop to eradicate that DEF light.
But you have to be able to SCN code the thing
Dennise
lindenengineering is offline
Old 08-25-2017, 04:13 AM   #24
rollerbearing
Originally Posted by vnvet View Post
......... I've taken other measures to ensure it never happens again.
That sounds a bit like you took the horse behind the barn and put it down. You didn't get rid of the van did ya?
rollerbearing is offline
Old 08-25-2017, 04:28 AM   #25
Bobnoxious
Bobnoxious's Avatar
Man, I brought one of those clone POS and gave it away. Ain't no way I am hooking it to my van.
Bobnoxious is offline
Old 08-25-2017, 02:23 PM   #26
vnvet
No. In fact it now runs like a race horse with more muscle and consumes less oats.
2013 3500 170 HT DWD CARGO 266K
2005 3500 5.9 CRD Ram Laramie 400k
1995 2500 Suburban 6.5 TD 470k
https://www.amsoil.com/
vnvet is offline
Old 08-25-2017, 05:12 PM   #27
rollerbearing
Ah - I got it. The horse is CURED!
Old 08-28-2017, 12:04 AM   #28
Kaiserro
I had the same problem twice. If you have a hard stop the fluid all goes forward in the tank and somehow out of the reservoir and shows the sensors not wetted. Bam there goes the 10 start countdown. I purchased an OBD2 module 2 clear and erase the DTC code just as if it had been done with SCN coding. Here is a link:
http://m.ebay.com/itm/MERCEDES-car-a...%257Ciid%253A7
This will reset it until the next time you have a problem. Then use it again to reset, again and again. Tied to your vehicle VIN# No more going to the dealer.
Kaiserro is offline
Old 08-28-2017, 12:08 AM   #29
Kaiserro
Kaiserro is offline
Old 08-28-2017, 12:14 AM   #30
Kaiserro
Kaiserro is offline
Closed Thread
