Old 11-04-2010, 03:13 PM   #1
02 Sprinter
Exclamation LED Headlight Bulbs???
There is a seller on Ebay selling LED replacement Headlight Bulbs for Sprinters. Claims 300% brighter and lasts longer and much cooler. Also mentions something about code potential problems? Anyone know anything about these??? Regards,02Sprinter
02 Sprinter is offline   Reply With Quote
Old 11-04-2010, 04:41 PM   #2
sikwan
06 T1N Can
sikwan's Avatar
Default Re: LED Headlight Bulbs???
Link?
Old 11-04-2010, 04:50 PM   #3
Please provide a URL or eBay item number when asking a question like this.
--dick (who tried "LED replacement Headlight Bulbs for Sprinters" on the eBay search bar, but zero hits)
Old 11-04-2010, 04:57 PM   #4
surlyoldbill
surlyoldbill's Avatar
I don't think there are any LEDs powerful enough to use as headlights at a reasonable price. An LED bulb for your home AC power that emits as many lumens as a 5-10 watt regular lightbulb costs over $50.
This begs the question: Why would you want LED headlights?
which leads to: If it's for power savings, then by reducing amperage draw would you get better MPG?
(do you get better MPG driving with headlights off?)
There is a lot of debate about using certain electrically powered accesories and the effect on MPG, thus it would reason that using one of the biggest amperage draws on the vehicle, headlights, would reduce MPG.
Former owner of Surly Mobile:
Old 11-04-2010, 05:35 PM   #5
LuckyDawgz Jim
LuckyDawgz Jim's Avatar
Many of the headlights, and other aftermarket accessories, on eBay are generic and are listed for every vehicle... just so they can gain a wider audience.
Don't believe everything you see on eBay... if if sounds too good to be true, it likely is.
2002 Freightliner C2500 SHC 158WB 113k
RV Conversion... Known as the "T1N TeePee" or "White Whale"
LuckyDawgz Jim is offline   Reply With Quote
Old 11-04-2010, 05:45 PM   #6
02 Sprinter
Exclamation Re: LED Headlight Bulbs???
I don't know how to attach a Link. But this is the item #290496131862. If you go to Ebay and search this item # you should find it..02Sprinter
Old 11-04-2010, 05:54 PM   #7
LuckyDawgz Jim
Here'sa link to the eBay listing:
http://cgi.ebay.com/ebaymotors/ws/eB...%3D1&viewitem=
Old 11-04-2010, 06:07 PM   #8
mackconsult
mackconsult's Avatar
Can't the sprinter ECU tell when there is a resistance change of something electrical in the van? Led's draw much less current than incandescent.
97 XR600R Honda Dual Sport Motorcycle
98 18' Avon RIB w/ 90 HP 4 stroke Yamaha
95 TDI Passat VW Wagon
08 Laser Pro #194171
Vancouver, Washington, USA
Sail Smart, Sail Hard, Then think about Sailing Fast !!!!!
http://www.mackconsult.com/
Some day I will sell everything, buy a cascade 36 or a cal 40 sailboat, and turn left at the Columbia River Bar !!!!
mackconsult is offline   Reply With Quote
Old 11-04-2010, 06:21 PM   #9
LuckyDawgz Jim
Here's the tipoff in the listing that it is a generic bulb:
Other Part Number: RV ATV QUAD TRACTOR AUTOMOBILE 169 194
Manufacturer Part Number: JDM CAR TRUCK MOTORBIKE BOAT LEDS LIGHTS GLOBE
Also this link, http://www.sylvania.com/ConsumerProd...de/default.htm
also included in the listing, is just a general vehicle bulb fitment listing from Sylvania.
This is a replacement "wedge bulb" which would be a for turn signal
http://www.autopartswarehouse.com/de...e&apwid8bBX9EW
Old 11-04-2010, 07:01 PM   #10
sikwan
06 T1N Can
sikwan's Avatar
LDJim is right. It is a bulb for the turn signal and not for the headlight.
