Old 02-18-2016, 09:42 PM   #1
MillionMileSprinter
Formerly Type2Teach
MillionMileSprinter's Avatar
Default Easy way to drain the T1N fuel tank
First if all, there's no *clean* way to do this, but this is the cleanest/easiest way I have tried yet.
I am replacing the in tank pump on a Sprinter and, of course, the owner just filled the tank! (It should be noted that this procedure only works on the '04-'06 models)
Here's the procedure:
Remove the fuel line on the fuel filter that comes from the fuel tank. It is the rubber line closest to the firewall. Get a container (I used a 5 gallon plastic fuel container) and place it between the drivers side front wheel and the transmission. Reach up with your hand and pull that loose fuel line down into the container. Turn the key to on, but not all the way to start. You should hear the fuel pump running and the container filling with fuel. Opening the fuel tank cap and putting your ear next to the hole allows you to hear the pump better.
The pump will run for 10-20 seconds and pump around half a gallon of fuel. When you hear the pump stop, turn the key to off and then back to run to run the pump again. Do this over and over until you have drained the tank.
Sprinter Mechanic
'04 long/tall Silver Passenger 156K (Totaled! 11/2018)
'06 long/tall White Passenger 180K
'06 medium/short Silver Passenger 265k
Joel Sell
For HELP, SERVICE and MORE
Visit: www.millionmilesprinter.com
Cooling System Kit: https://www.millionmilesprinter.com/...n-life-cooling
Follow me on Instagram: https://www.instagram.com/million_mile_sprinter/
MMS YouTube Channel: https://www.youtube.com/channel/UCuq...mQ8mWdgF1XpLhg
MillionMileSprinter is offline   Reply With Quote
The Following 2 Users Say Thank You to MillionMileSprinter For This Useful Post:
merman (10-24-2018), seans (02-20-2016)
Old 02-18-2016, 10:36 PM   #2
NelsonSprinter
Former Nelson BC Sprinter
NelsonSprinter's Avatar
Default Re: Easy way to drain the T1N fuel tank
Does this drain all fuel from the lowest point, or does it drain most from an upward tube until the level reaches the bottom of the tube, and leave dirt and water in the bottom?
Previous owner of '02 FL 2500 140WB Cargo door windows, 15" Alloys, LT235/75R15-E Nokian Rotiivas, Nokian Hakka C studded winters, Curt 4 hitch, 3.72 rear with 30MPG Cdn GDE ECO Tuned. . .
I am NOT a MECHANIC, I just play one online.
'02-'03 Fuel filter leak fix http://sprinter-source.com/forum/sho...ix+fuel+filter
15" tire options http://sprinter-source.com/forum/sho...t=tire+options
NelsonSprinter is offline   Reply With Quote
Old 02-18-2016, 10:57 PM   #3
MillionMileSprinter
Formerly Type2Teach
I know it sucks the fuel up through a plastic screen on the end of a tube that comes down at an angle. I had to quit for the day once I finished pumping out the tank. I won't get to dropping the tank until early next week and I will let you know what I find.
Sprinter Mechanic
Joel Sell
Old 02-18-2016, 11:12 PM   #4
Aqua Puttana
Poly - Thread Finder
Aqua Puttana's Avatar
A simple jumper can save a bunch of key on/off cycles.
Some info is here.
http://sprinter-source.com/forum/sho...560#post210560
MillionMileSprinter (02-24-2016), seans (02-20-2016)
Old 02-24-2016, 09:47 PM   #5
mawsea
sprinter guru
mawsea's Avatar
My 2003 does not have the in-tank pump. I went down to the local auto parts store and bought a universal, inline, 12v diesel fuel pump and hooked it up to the inlet hose at the filter and sucked all 25 gallons out. I paid $55 for the pump but I see them on Amazon for around $25.
Original owner: 2003 2500 144 low cargo 200,000 miles, outfitted for work and play
mawsea is offline   Reply With Quote
The Following 2 Users Say Thank You to mawsea For This Useful Post:
Aqua Puttana (02-25-2016), MillionMileSprinter (02-24-2016)
Old 02-27-2016, 08:07 AM   #6
misterbond10
misterbond10's Avatar
Wont draining it all the way will suck up a bunch of crud into the fuel pump??
2006 Dodge Sprinter 2500, 140" WB, OM647 Engine 2.7L
misterbond10 is offline   Reply With Quote
Old 02-27-2016, 02:36 PM   #7
One call a/c
One call a/c's Avatar
Default
Just simply drill a hole in the bottom 😏 👍🏻
2006 Long n Tall Cargo.
One call a/c is offline   Reply With Quote
Old 02-27-2016, 03:53 PM   #8
Aqua Puttana
Probably no more than when the tank gets low and stuff gets sloshed around.
The flow rates are not that great. The fuel pickup won't act like a shop vac hose.
Old 02-27-2016, 06:14 PM   #9
sebtown
When I mistakenly filled my Sprinter with gasoline last year I realized my mistake before I started the engine. I had it towed to a shop where they used a small electric pump attached to the inlet hose at the fuel filter and pumped the tank dry. Refilled with clean diesel and I have enjoyed over 10,000 trouble free miles since. I now double and triple check the pump before fueling. Best of all I was only charged $49 to pump the tank and even with the cost of the gasoline I was only out $100. Drilling a hole in the tank is a terrible idea in my opinion.
2006 Freightliner
sebtown is offline   Reply With Quote
The Following User Says Thank You to sebtown For This Useful Post:
Aqua Puttana (02-27-2016)
Old 02-27-2016, 06:39 PM   #10
MillionMileSprinter
Formerly Type2Teach
I'm pretty sure that the drilling a hole comment was a joke. And as far as if the pickup gets the fuel from the lowest point, I would say no. If you stick your head under the fuel tank, you will see a spot about in the middle that is a circle. The bottom of the fuel pump is sitting in that indent. That appears to be the lowest part of the fuel tank. However, the pickup for the pump is actually located about 6 inches off to the side of the actual pump (the black straw with the white tip in the photo).
Sprinter Mechanic
Joel Sell
Aqua Puttana (02-27-2016), CJPJ (02-28-2016)
