Old 05-12-2019, 03:16 PM   #1
Rocky Mtn Sprinter
Default XM Radio
I have a 2018 Pleasure Way Plateau FL and am wondering if the factory installed radio (junk) can accept XM/Sirius radio? Found nothing in the manual and calls to my dealer haven't been returned as of yet.
Rocky Mtn Sprinter is offline   Reply With Quote
Old 05-12-2019, 09:54 PM   #2
Onefin
Default Re: XM Radio
No provisions for xm with the audio 15.
If you want it to look factory: Youíll want to call or email and verify exactly what model you need from these guys https://www.vaistech.com/product/gsr-mb02-w-tuner-kit/
If you donít care how ghetto it looks use this https://shop.siriusxm.com/onyx-ez-vehicle.html
I use the latter and one day will pony up for the former.
The Following User Says Thank You to Onefin For This Useful Post:
Rocky Mtn Sprinter (05-12-2019)
Old 05-14-2019, 08:20 PM   #3
bigpapaporsche
We have a 2017 Pleasureway XL TD and wanted XM Radio also and were very disappointed to learn it was possible. Its hard to understand why in this Day & Age XM Radio isn't standard equipment on a vehicle of this caliper!
bigpapaporsche is offline   Reply With Quote
Old 05-23-2019, 11:36 PM   #4
hotfudge
2015.5 Unity TB
I have the XM Onyx radio/base hard wired on our Sprinter dash behind the speedo. It plays through the Audio 15 and upgraded speakers plus sub woofer. I move the Onyx between our MH, home dock and another vehicle dock. That way, only ONE account for three locations.
hotfudge is offline   Reply With Quote
Old 05-24-2019, 04:48 AM   #5
Onefin
I too have the Onyx and have had one since 2014.....theyíre cheap (sometimes free with a new subscription) and easy.
I just hate the way they look.....
If I had multiple locations like you do , Iíd rethink that....Iíd never want to pay 3x monthly xm fees....
Old 06-04-2019, 10:32 PM   #6
skipsteller
I have the Onyx on a sandbag mount in my 2016 Ascent. It sits in the cubby hole behind the speedo and plugs into the accessory jacks on the right side of the cubby hole; one for signal and one for power. The antenna wire is routed down the front of the dash beside the speedo, but you can't see it because it's tucked in the crack where two parts of the dash come together. It then goes under the dash, out of the firewall into the engine compartment, out of the engine compartment beside the drivers side hood hinge, then under the rubber window seal, then straight on up to the front edge of the roof (this last part is covered with metal tape and stays put). The antenna stays where you put it with the magnetic mount. I also have a remote for easy channel surfing. It's neat and great signal.... just wish I had a better stereo system :)
skipsteller is offline   Reply With Quote
Old 08-29-2019, 11:36 PM   #7
Dja06422
5 bucks a month to stream xm radio. Works good assuming reasonable cell phone reception. Data usage not too bad. I installed a 2nd Bose Solo5 sound bar on my front tv on my 2020 Plateau FL and connect to it via bluetooth. Time will tel....
Dja06422 is offline   Reply With Quote
Old 08-30-2019, 02:17 PM   #8
South Bird
I gave up on the standard unit and installed the Alpine Halo 9. That way, I can get both Sirius XM and Apple CarPlay. There are several applications that let you download Maps for when you go to areas without cell coverage to continue using the GPS. Navigation. They’re also models with smaller screens for less money And the same features. I upgraded the speakers as well and it makes a substantial difference.
South Bird is offline   Reply With Quote
