Old 01-23-2014, 03:58 AM   #1
Tuktu
2010 Regency GT, Triple E
Default Refridgerator
I have been meaning to ask if the refrigerator works good and can keep things(beer)cold. Nothing worse than a RV fridge that does not keep food and drinks cold.
Shane
Tuktu is offline   Reply With Quote
Old 01-23-2014, 12:25 PM   #2
Eastbayview
2012 Unity MB
Eastbayview's Avatar
Default Re: Refridgerator
Shane
I think the fridge works well when it is running on propane. Keeps things frozen in the freezer. 12 volt will not cool well, just maintains the current temp. 120v would be the second best choice.
2011 NCV3 3500 Cab Chassis with 2012 LTV Unity MB.
Eastbayview is offline   Reply With Quote
Old 01-23-2014, 12:30 PM   #3
jackfish
+1
You learn something every day whether you want to or not.
jackfish is offline   Reply With Quote
Old 01-23-2014, 12:51 PM   #4
Old Crows
Calypso 2014 View Profile
Old Crows's Avatar
On my third RV fridge (3 different RVs). All were 110V/12V/LP selectable. 2 were automatic power selection, 1 manual. All could get cold enough to use the freezer compartment ... Even in Texas summertime. Power source didn't matter. They all take time to get down to the selected temperature regardless of power choice. Once cold, they stayed cold.
Do pre-cool or freeze your vittles before putting them in the fridge. Keep the door SHUT as much as possible. Make sure the fridge has adequate chimney space and openings at the top and bottom for adequate air flow. They perform best when nearly level....
Old 01-23-2014, 01:08 PM   #5
Peter Tourin
2012 LTV Unity MB
Peter Tourin's Avatar
+1 > They perform best when nearly level.... <
You really notice this when you park on a slope once your fridge is cold, and over the afternoon it goes up 10 degrees... I carry a cheap levelling bubble and check for level whenever it's practical to do so.
I also experience that 12vdc doesn't do much for dropping the temp in the fridge - but it'll keep it cool once it's already cool.
Peter Tourin
2012 Leisure Travel Unity MB
Peter Tourin is offline   Reply With Quote
The Following User Says Thank You to Peter Tourin For This Useful Post:
Old Crows (01-23-2014)
Old 01-23-2014, 01:13 PM   #6
FlyingBreadBox
Mine is a Tundra unit 120ac / 12 volt (actually 12 volt with a converter built in) It cools and freezes just fine. Humans like the van to be level too, for sleeping.
FlyingBreadBox is offline   Reply With Quote
Old 01-23-2014, 01:46 PM   #7
Peter Tourin
2012 LTV Unity MB
> Humans like the van to be level too, for sleeping <
Yeah, that's one of my rules of thumb - if the rig is noticeably tilted when I lie down, the fridge will probably be unhappy <g>...
I find that the problem is more likely to show up when I park some place that's on a big slope during the day, go hiking for 5 hours, and come back to find a warm fridge. My impression is that this is a problem both on LP and on 12vdc - I assume it's a problem of coolant flow in the coils rather than the power source for the cooling.
Peter Tourin
Old 01-23-2014, 07:13 PM   #8
jackfish
I've got the free Bubble Level app for my iPhone. Works great!
The Following 2 Users Say Thank You to jackfish For This Useful Post:
Peter Tourin (01-23-2014), wyogirl (06-07-2016)
Old 01-23-2014, 08:59 PM   #9
Peter Tourin
2012 LTV Unity MB
Thanks Jackfish, never thought to check for one. I just picked up a freebie - Handy Tools Surface Level - simple, measures 2 dimensions and shows the X and Y axis inclination in degrees. Very cool!
Peter Tourin
Old 01-23-2014, 09:22 PM   #10
Graphite Dave
Dave Orton
One way that works well is to cut a piece of wood that is 1/16 the tread of the Sprinter wide X 1/16 the wheelbase long. The Lynx plastic blocks are 1" thick so 1/16" thick steel washers are in scale to the block. Screw a two way level to the piece of wood. Place wood on sink top and add washers under the corners until block is level. Count the number of washers at each corner and that is the stack height required at that wheel.
http://sprinter-source.com/forum/sho...1&postcount=29
The Following 4 Users Say Thank You to Graphite Dave For This Useful Post:
cherylandtk (01-30-2014), Dcdude (06-02-2016), mozart (02-28-2015), Peter Tourin (01-24-2014)
