Old 09-04-2019, 08:46 PM   #1
bcolins
2004 158" Vista Cruiser
bcolins's Avatar
Default I removed the mirror behind the stove, What is holding the flimsy wall paneling on??
I removed the 70's looking mirror panel that was on the paneling behind the stove,....I want to remove the vertical panel joint cover that hides the vertical panel joint to the right of the stove and sink area so that I can install a stick on subway tile backsplash on the entire wall panel over to the end of the counter space.
Thinking I probably have to remove or at least move the panel a bit to get that vertical panel joint cover out of the gap between the two panels,.....uncharted territory for me,...
Anyone been there,....done that?
Brian in San Antonio
Old 10-06-2019, 06:24 PM   #2
Smbrick
Default Re: I removed the mirror behind the stove, What is holding the flimsy wall paneling o
I had the exact same dilema on a previous RV, and I ended up just using a razor knife and cutting the plastic seam connector so it was flush and left the back portion of it in place, behind the panels. It worked fine.
2006 Frieghtliner 2500 158" Hi-top - Gulf Stream Vista Cruiser MB
Smbrick is offline   Reply With Quote
The Following User Says Thank You to Smbrick For This Useful Post:
bcolins (10-06-2019)
Old 10-06-2019, 07:25 PM   #3
bcolins
bcolins's Avatar
Thats a good idea. Thanks Rick.
Brian
