Old 11-26-2018, 06:07 PM   #1
lance_k
Default Winterizing
I've opened the 3 drain points under the fridge, opened all water faucets (shower, bathroom shower and kitchen sink hot and cold knobs) ran the pump til dry. Drained the water heater, and used a leaf blower into my water intake hole to push air in and any water out.
Anybody have sage advice here to winterize? It's pretty cold here in Oregon during the winter. I was planning on keeping a few anti-mold/mildew low amp air dryers in there too that may keep it a bit warmer as well.
lance_k is offline   Reply With Quote
Old 11-26-2018, 06:17 PM   #2
outbound
06/2500/140
Default Re: Winterizing
might want to use a compressor into the city water inlet and blowout any remaining water from the lines, MAKE SURE YOU FLUSH THE TOILET TIL DRY
and/or if so equipped, use the winterizing bypass on your water pump to push rv antifreeze thru the entire system
or... if yer so inclined, buy a 1.75L bottle of cheap vodka and use that instead of antifreeze... (then no need flush in the spring ;)
not much time at the moment, so cant go into much detail, but that's my strategy
outbound is offline   Reply With Quote
Old 11-26-2018, 07:12 PM   #3
avanti
2014 GWV Legend 3500 I4
avanti's Avatar
You definitely need to get an adaptor like this:
and use it with an air compressor to properly blow out all of your fixtures. There are many tutorials on the Web about how to do this.
You need to put pink anti-freeze in all your drain traps and in your macerator if you have one. I personally would NEVER put pink stuff in your potable water system.
--Pete
The Following 2 Users Say Thank You to avanti For This Useful Post:
barsip (12-03-2018), outbound (11-29-2018)
Old 04-27-2019, 07:37 PM   #4
lance_k
Seems like I may have not done as good a job winterizing. My water pump will not stop running... keeps gurgling building water pressure. Likely related to my previous post, one of the drain "T" plugs could be leaking that pressured air. But it certainly seems like the pump just has a ton of air gurgling in it. No water leaks as far as I can see. Hmmm... =(
Old 04-27-2019, 07:47 PM   #5
avanti
avanti's Avatar
First thing to check is the clear plastic cap over the little filter screen that you probably have at the inlet of your water pump. You should always remove this cap for winter storage. Residual water tends to accumulate there and it is easily damaged. If that is the problem, replacements are readily available and inexpensive.
--Pete
Old 04-28-2019, 01:46 AM   #6
lance_k
I did drain that clear plastic cap when winterizing. it is watertight and not leaking currently.
