CV Boots
Mattyk
Hi Perce some good info right here
https://sprinter-source.com/forum/showthread.php?t=59475&highlight=boots
The inner boot closest to diff is very common, most driveshaft repairs will have something that fits of the shelf. I installed new cv and boots the same as mentioned in the above post.
The outer(closest to wheel) I installed genuine merc ones which were very expensive $175.00 each boot as I was in tasmania at the time.
However I have ordered another set of outer boots from eBay in the U.K.
The company name is Carpartsinmotion. From memory it was around $65 delivered for 2.
I have attached the ones I have ordered which I will keep for spares.
Hope that helps
Perce
Thanks all, refitted a new boot sourced from the UK, I have a spare if anyone needs one urgently.
Perce
It fitted fine, the cone that came with the kit helped, grease seamed OK. Regards Percy.
