Old 07-08-2019, 03:56 PM   #1
mickal
Default what is max boost
dodge sprinter 2500 , 2006 high roof and 158''
the max boost i got was 19, is it ok or should be higher.
the speed 127 km/h and the boost was always going down then back up againn and repeat. is it because reach max speed of my sprinter.
had only about 300 lb in cargo.
mickal is offline   Reply With Quote
Old 07-08-2019, 04:51 PM   #2
calbiker
Default Re: what is max boost
Units behind 19 are??
Not sure what max is, but I see 35 psi.
calbiker is online now   Reply With Quote
Old 07-08-2019, 05:08 PM   #3
mickal
The dial is 0 to +22 and other side 0 to -22
Will sélect a display in PSI next time
Old 07-08-2019, 05:12 PM   #4
19psi boost (35 map) is normal at sea level.
mickal (07-08-2019), Nautamaran (10-26-2019)
Old 07-08-2019, 05:19 PM   #5
marklg
I believe max boost is about 20 psi. That will happen on hard acceleration. Normal operation will be lower. It will vary from almost 0 to 20 depending on driving conditions. Most often it will be between 5 and 15 psi.
Regards,
Mark
The Following 2 Users Say Thank You to marklg For This Useful Post:
Aqua Puttana (07-08-2019), Midwestdrifter (07-08-2019)
Old 07-08-2019, 06:07 PM   #6
Upon acceleration my 2004 with mechanical boost gauge will spike up to around 22 psi briefly, and then immediately settle back to the 19 psi mentioned, or typically even lower. When in the correct gear, even when climbing grades the boost pressure settles back.
The mechanical boost gauge reading is not affected by altitude like the MAP reading is.
Old 07-08-2019, 06:12 PM   #7
When testing the intake plumbing for leaks, MB's recommended maximum inflation pressure is 20 psi (above ambient).
The Sprinter actually *measures* Absolute pressure: so the sea-level range is from 14.7 to 32 (ish) psi
That corresponds to a "boost" of zero to 17+ psi ("boost" is what's called "gauge" pressure in the engineering biz)
p.s. the cylinders don't know nor care about ambient pressure ... they only care about what's crammed down their throats by the turbo system. The sensor plugged into the intake plumbing is an absolute sensor.
p.p.s. ... and is fun to use as a barometric altimeter: when parked up on Bryce Canyon's 9500' ridge, i'll see 11.5 psi before i start cranking the engine.
Nautamaran (07-09-2019)
Old 07-08-2019, 06:20 PM   #8
calbiker
Looks like Mercedes C3 scanner defines boost pressure differently. Without engine running, boost pressure is equal to atmospheric pressure.
Old 07-08-2019, 06:25 PM   #9
Boost is gauge pressure, MAP is absolute. We generally only care about boost, as we are concerned with turbo operation. The ECM needs MAP, to compare to air mass readings.
Old 07-08-2019, 06:28 PM   #10
marklg
The Autel provides three pressure sensor readings:
As I understood it, the vehicle subtracts the readings from two sensors to determine what it thinks the boost is. I think it is the boost and atmospheric sensors, but there are three to choose from it seems.
Regards,
Mark
