Go Back   Sprinter-Forum > Regional Discussions > Canada
Old 06-30-2019, 02:32 PM   #1
jaycowan
Default Rear Heater
Hello all, I don't know of this has been discussed already, but I am wondering how to heat the rear of the van overnight in the winter?
I am able to plug it in, and the back is insulated and carpeted. I cannot have my materials freeze, and I don't want to keep it in my warehouse overnight as its not that close by!
Has someone figured out the best way to do this efficiently? I was wondering about wiring a plug below the filler cap area so I can plug directly in with all the doors closed?
Any help would be great!
Jay
jaycowan is offline   Reply With Quote
Old 07-05-2019, 02:51 AM   #2
BrennWagon
Pete
Default Re: Rear Heater
A plug in oil filled radiator type space heater is probably the safest bet. You could just run an extension cord out the back door or could certainly install a 120v port into the exterior of the van
BrennWagon is online now   Reply With Quote
jaycowan (07-06-2019)
Old 07-10-2019, 02:00 AM   #3
BritzSprinter
Ex Britz 313CDI Motorhome
Eberspacher or Webasto diesel heater might be an option, they use very little fuel and are thermostatically controlled.
BritzSprinter is offline   Reply With Quote
The Following User Says Thank You to BritzSprinter For This Useful Post:
jaycowan (07-12-2019)
Old 07-10-2019, 09:22 PM   #4
I use one of the roll-around oil-filled radiators that BrennWagon mentions ... and i have a flat 6-foot (2 meter) extension cord that i run out through the edge or bottom of the front door's seam.
(i have a T1N, so an NCV3 fitment might differ).
At roughly freezing (or a little below), having the radiator set to "3" (out of 10) and only using the 600 watt setting keeps us at 55 F about 2 feet off the floor.
Other differences: i have a 118" wheelbase, so my cargo area is only 8 feet long (i have only a thin curtain as a "barrier" from the front cab). Total cargo-area volume about 200 cubic feet. Uninsulated glass windows all around.
A longer wheelbase will have a proportionally greater volume you're trying to keep warm.
The radiator can be seen in the background of this shot, cowering under the microwave:
