Old 06-08-2019, 07:53 PM   #1
grantwilson
FreedomVanGo
grantwilson's Avatar
Default EV2, 2019 4x4
As always, 100% transparent with my builds that roll out, so heres another one! EV3 is shortly after on a 170 2019 2wd
Untitled by Grant Wilson, on Flickr
Interior color selection.
Walls
Floors
Countertop
Cabinet faces are the white scroll pattern, and sides and bottoms are white
White powdercoat
BFG 285/75-16
Gotta pull the mudflaps and no issues. They do rub on the flaps
Buildout includes:
200 watts of Renogy solar
Adventure Wagon RUV Interior Kit :
Electrical – A complete wiring harness and accessories to power the van cabin. The fully assembled and loomed harness connects to the stock Sprinter battery and includes leads for two fans, six lights, four UBS ports, four 12v ports, and two accessories (heater, sink, etc.). The included LED lights are dimmable and can switch to red. The eight included power ports are marine grade. All installation hardware is included and all wire ends connectors are installed.
Insulation –Hushmat sound deadener, 3M Thinsulate wall and ceiling insulation to match the Sprinter interior cavities, and double-sided tape for installation. All interior panels also have reflectix installed on the backside for added sound and heat insulation.
Ceiling Fans – Two Maxxair ceiling fans, with mounting base, trim ring, weather seal, electrical connections and installation hardware.
Wall and Ceiling Bracers – Powder-coated, pre-assembled bracers used for L-track installation points and to support our optional bed and storage systems. Includes all hardware.
L-track – Aircraft-style L-track pre-cut and pre-drilled. Four (144WB) or six (170WB) vertical wall tracks, four horizonal wall tracks and three ceiling tracks with mounting hardware.
Wall and Ceiling Panels – Cut-to-fit 6mm marine-grade, plywood panels, upholstered in your choice of 4 standard fabric colors, and backed with Reflectix insulation. Pre-drilled for mounting power outlets. Ceiling panels are cut out for fans (if needed) and the six LED lights are already installed. All installation hardware is included.
Molded Trim – Custom-made, upholstered interior panels to complete areas above sliding door, behind driver’s head, and driver’s side crew window. Mounting hardware included.
Luxury Vinyl Plank Flooring
Under Floor Insulation
Aluminum Framed Interior Components:
Wheel well covers with hinged lid
Queen Bed Platform, north to south
Fridge slide mounted cabinet with drawer
Galley Unit with 3 drawers, 2 doors
3 Upper Cabinets (exchangeable for Soft sided Upper Cabinets)
Laminate cabinet doors, sides and bottom
Galley includes:
Plug and play to a 12v source
Dometic Sink and Stove Combo
Water Pump
1lb Propane Tank holder
All Plumbing and propane regulator
12v Water pump
2 5 Gallon Tanks
Quick Disconnect for water tank
Switch for Water Pump
Ability to mount Lagun table already engineered, just add table and mount
Dometic CFX50 Fridge unit
Dometic CFX50 Slide
Alpine Mechanism Seat Swivels where applicable
AMAuto OEM Style Bonded Sliding Passenger window with screen
Ctek DC to DC charger under driver seat
Ctek Bluetooth Battery Monitor
100AH Renogy AGM Battery under passenger seat, optionally in engine bay (required for heater installation)
All Marine grade wire, heat shrink terminals
Upgrades:
Flarespace with tern window
BFG Tires
Owl Vans Tire carrier and Sherpa
Goal zero yeti 1400 with vehicle integration wiring
2019 Built 4x4 for sale
2018 Built 4x4 for sale
FreedomVanGo - Jacksonville Florida
The ONLY Certified Adventure Wagon dealer and installer in the SouthEast
Authorized Dealer for Dometic, Ripplewear, Tern Overland, Van Compass and more!
www.vangooutdoors.com
www.youtube.com/GrantWilsonFL
www.Instagram.com/FreedomVanGo
grantwilson is offline   Reply With Quote
The Following User Says Thank You to grantwilson For This Useful Post:
VanGoSki (06-09-2019)
Old 06-14-2019, 03:01 PM   #2
grantwilson
FreedomVanGo
Default Re: EV2, 2019 4x4
Just random update as im prepping for parts to get here.
Finished up a Revel on 35s, and took some side by side
Resetting the shop with two vans (ev3 is here soon as well)
Nice and clean now
Adding mount tabs to all the framing in order to have hidden fasteners on all future interiors for a cleaner look. Not everyone is like me and likes having pretty screws. So chopped, and punched a ton of tabs
and all welded up.
ill drop them off at powdercoat and start putting it together
Flarespace flares and tern overland windows came in as well, dropping them off to paint today as well as finishing registration.
Floor is being built by my cabinet guy, 3/4 cabinet grade ply flooring for awesome screw bite and mounting.
Onefin (07-02-2019)
Old 07-01-2019, 06:20 PM   #3
grantwilson
FreedomVanGo
And progress!
three vans of worth of interiors
Galley Assembly
Flarespace cut out and installed! Waiting on the forward window to get here.
The Following 4 Users Say Thank You to grantwilson For This Useful Post:
Ken S (07-03-2019), Onefin (07-02-2019), VanGoSki (07-02-2019), zither99 (07-02-2019)
Old 07-12-2019, 03:54 PM   #4
grantwilson
FreedomVanGo
mounted up the rack we make and a manual dometic 9500 awning (which are discontinued)
Also mounted all the L track and Ceiling tracks, cut holes for fans, ran electrical harness and sound deadening for the van. Today ill put in the fans, and start connecting wiring!
VanGoSki (07-13-2019)
Old 07-23-2019, 09:23 PM   #5
grantwilson
FreedomVanGo
Trim rings came in for the Flarespace flares.
Took the old walls, and made a new template combining them, and with the trim ring, so now I can have some templates made with my CNC guy to have them around. I have three sets of vans to install currently so it works out well.
Need to wrap everything with fabric and get it installed!
Old 07-24-2019, 03:33 AM   #6
grantwilson
FreedomVanGo
and got the passenger side upper wall in as well!
Surveillance Van (07-24-2019)
Old 07-26-2019, 01:35 PM   #7
grantwilson
FreedomVanGo
Lower wall, electrical, and wheel well box installed
Trim wall panels are being cut today via CNC, fabric should be here as well, so i can get that all done!
Old 07-27-2019, 03:14 AM   #8
VanGoSki
So two fans plus 200W of solar, on a 144"? I'd be interested in seeing how you fit panels on that.
VanGoSki is offline   Reply With Quote
Old 07-27-2019, 12:48 PM   #9
GSWatson
2013 144
GSWatson's Avatar
I did the same on the last conversion. The Renogy slim panels, at a little over 19 inches with each, just fit between two MaxxAirs. I can’t find a better picture, but this gives you an idea. I’m sure Grant has a better shot of one of his vans.
The Following 2 Users Say Thank You to GSWatson For This Useful Post:
kfgiesler (09-15-2019), VanGoSki (07-27-2019)
Old 07-27-2019, 09:00 PM   #10
VanGoSki
Thanks, Greg. Very helpful. Still quite a bit of roof left to puzzle in some smaller panels as well I imagine. How do you like having two fans in a 144?
The Following User Says Thank You to VanGoSki For This Useful Post:
dijuka (08-08-2019)
