Old 04-28-2019, 05:04 PM   #11
trc.rhubarb
Default Re: Armrests/covers cheap on fleabay
Originally Posted by alexk243 View Post
And these cheap arm rests mounting holes line up with them also? The auction had no mention of vehicle fitment.
They did on mine. They are nearly identical copies - might even be the same thing without the logos. Likely lower quality but can't be worse than what I replaced.
Also, if you keep watching, I got a pair for $49 shipped.
2003 Sprinter 140 SHC Moto/ADV Hauler
Please excuse any offensive or gibberish posts - I'm suffering a TBI and don't always think clearly.
trc.rhubarb is offline   Reply With Quote
The Following 4 Users Say Thank You to trc.rhubarb For This Useful Post:
alexk243 (04-28-2019), autostaretx (04-28-2019), DesertAdventures (05-20-2019), SD26 (05-08-2019)
Old 04-28-2019, 06:56 PM   #12
Are you referring to the holes for the top cover screws, or the swivel mounting to the side of the seat? Most of the pictures I've seen appear to have a 2 hole swivel mount to the seat.
I might even be tempted to buy a pair if they bolt right up to the 3 holes on the side of the Sprinter seat.
It might be helpful if you could include the specific listing title for what you bought. Using adjustable truck armrest gets a bunch of choices. The eBay listing link often changes, but the title wording usually remains the same when offered again.
Thanks for the info so far.
Old 04-28-2019, 07:08 PM   #13
Thanasis
Thanasis's Avatar
None of the knock-offs I was able to find on ebay had metal brackets matching the T1N's. Any one had a better luck?
This is what it should look like:
2006 T1N 140 2500 DIY Conversion, High roof, 2.7L, - "Tallac"
Thanasis is offline   Reply With Quote
Old 04-28-2019, 08:51 PM   #14
I was thinking that an adapter plate for the 2 bolt to Sprinter wouldn't be too difficult to fabricate. The critical part would be to get the height the same. That may even be somewhat forgiving if the replacement has the level adjustment similar to the OEM armrests.
Another possibility.
Install the 2 ea. OEM to the driver position. Install the adapted armrests on the co-driver seat so they would be matched in height. That leaves the driver vs co-driver armrest covers looking different. I understand why that wouldn't be acceptable to some owners. A possible solution would be to install matching armrest covers on the inside position armrests. The different covers on the door sides would be mostly unnoticed. That is particularly true when they are rotated to the up position.
Glasseye's comment about 2 ea. armrests being nice spurs my interest. The search continues.
Old 04-29-2019, 01:21 AM   #15
trc.rhubarb
I'll have to grab pictures of them when I am next at "my house"...
I'm on my own these days and while I still store stuff there, I can't just drop by without her permission.
I think I can go in the garage on Wednesday when i drop off my daughter.
I'm pretty sure the two holes lined up with the upper 2 OEM homes but I didn't put calipers on it.
I will when I get there next.
Meanwhile, the van looks so much better without the grimy, chewed up pads.
People aren't grossed out by it anymore. Now i just need some form fitting seat covers.
This is the link to what I bought.
https://www.ebay.com/itm/2X-Universa...72.m2749.l2649
Old 04-29-2019, 03:41 PM   #16
I'm pretty sure the two holes lined up with the upper 2 OEM holes but I didn't put calipers on it.
Thanks again. A measurement on the hole centers for the aftermarket unit would be helpful.
If they are close to OEM then the idea of installing the aftermarket set on one seat would probably work fairly easily.
The armrest foam can look terrible as it wears out. I colored some HH66 cement with gray paint and painted the HH66 on the slightly worn ends. Not perfect, but better than the exposed tan color foam. I suppose just gray paint alone might work, but would have less body against wear.
Old 04-29-2019, 05:10 PM   #17
alexk243
KulAdventure
alexk243's Avatar
So the two top holes line up with the T1N chairs, but there is not an aftermarket one with the third hole?
Do they hold up pretty well with just two bolts holding it? I like the idea of having two different front seats and using the factory ones on the driver seat.
2004 T1N Passenger 140" (Conversion in Progress - Build Thread)
My Website/Blog with Projects and Write Ups on my Van
alexk243 is offline   Reply With Quote
Old 04-29-2019, 06:49 PM   #18
Do they hold up pretty well with just two bolts holding it?...
Good question. 3 must be better over the long haul. The design on many of the offerings is only two fasteners, so I'd assume it's sufficient. Some of the other brand OEM armrest units I ran across only have 2 ea. fasteners.
It would be nice if just the 2 ea. can be properly aligned to a Sprinter.
Old 04-30-2019, 05:52 PM   #19
alexk243
KulAdventure
alexk243's Avatar
I think they pulled the listing off ebay... anyone able to find it anymore?
Old 04-30-2019, 06:22 PM   #20
This is the title from the link.
2X-Universal-Adjustable-Car-Seat-Comfort-Armrest-Console-Box-For-Truck-Van-Boat
Try a search leaving the dashes out.
Mickyfin (05-01-2019)
