Old 02-11-2019, 11:46 PM   #1
bcman
bcman's Avatar
Default Sliding Door Roller Mod
I've replaced the center door slide mechanism (AKA body slide) twice on my van when one of the smaller plastic rollers gets crushed/deformed and won't roll properly. Those rollers are just pieces of plastic spinning on steel shafts, so it's just a matter of time until they wear out in one way or another. I decided to try upgrading them to cartridge ball bearings. (I'll let someone else insert the quote from Fletch.)
Enduro DR 1017 2RS MAX bearings are 10 mm ID, 17 mm OD, and 6 mm wide at the outer race. Pretty close in dimensions to the plastic rollers. I ground off the peened ends of the steel pins and drove them out with a drift. I then turned some bearing supports/spacers from 7/16 stainless rod on the lathe, then bolted them into place with M6 flat head cap screws and nylock nuts.
One of the plastic rollers is shown removed, along with one bearing assembly.
I installed the fixed mechanism last night. It took a little adjustment of the T45 Torx head bolt to get the door lined up to latch properly, but seems to be working like a charm. I'll post a long-term update in a few months.
bcman is online now   Reply With Quote
The Following 6 Users Say Thank You to bcman For This Useful Post:
Aqua Puttana (02-12-2019), autostaretx (11-21-2019), kayakkingoz (11-23-2019), Midwestdrifter (11-21-2019), Onefin (11-22-2019), TheHerd (02-12-2019)
Old 11-21-2019, 04:42 AM   #2
bcman
bcman's Avatar
Default Re: Sliding Door Roller Mod
Update: After 9 months, these little bearings are still going strong. No sign of increased wear on the track, either.
I had access to them through my previous bike-industry job, but they're available here. You're on your own for the stainless spacers, though.
The Following User Says Thank You to bcman For This Useful Post:
Old 11-21-2019, 05:00 AM   #3
jackbombay
Stacking up washers should work fine, yea?
Old 11-21-2019, 11:35 AM   #4
Cool mod, thanks for posting.
Old 11-21-2019, 09:01 PM   #5
For that inevitable day when his remote photo site link breaks:
Old 11-23-2019, 07:06 AM   #6
bcman
bcman's Avatar
Maybe. The screw is 6mm, but the inner diameter of the bearing is 10mm. The bearing will center on the screw due to the conical screw head, but side loading could bend the screw and cause the bearing to slide on the washers.
The piece I turned on the lathe is shown above in light blue. It takes up the space between the screw and the inner race of the bearing.
Old 11-23-2019, 12:27 PM   #7
You may be able to substitute a 10mm shoulder screw with some washers? That would probably be strong enough.
Old 11-23-2019, 11:06 PM   #8
I wonder if a sleeve would work with the flat head screw?
4pcs 10mm Length x 10mm OD x 8mm Bore
https://www.amazon.com/Length-Silver.../dp/B00N415FCU
The taper head should center the sleeve. Compression should bind the bottom.
