Old 11-22-2019, 02:37 PM   #11
Shortiez
Default Re: Suspected drive shaft u-joint noise. Thoughts?
Thanks for the post Wubalubbadubdub.
I've got the same issue. It's the front u-joint. On road trip now, probably about 1500 miles until I can fix it myself by replacing the u-joint. (Not so hard, even though MBZ says you have to change the driveshaft.) Or I could hire a shop to do it sooner at a significantly higher inconvenience and cost. Was there any damage from running around with a bad u-joint for a while? Damaged rear transmission bearing or seal? Damaged drive shaft, etc?
Zach from California
has a pair of 2006 118" WB T1N Sprinters
Converted from life as plumbing vans to little RVs
Two other MBZ products: a 2002 W210 and a 2004 W211
Shortiez is offline   Reply With Quote
Old 11-22-2019, 04:26 PM   #12
wubalubbadubdub
No damage, but mine wasn't so bad that it was loose/vibrating. It was only squeaking.
wubalubbadubdub is offline   Reply With Quote
Old 11-22-2019, 05:43 PM   #13
Shortiez
Again, thanks very much. I might just leave it for a while then. It doesn't make much noise while cruising.
