Old 02-08-2013, 02:30 PM   #1
dirtyguy
Default House charger location on Citation Sprinter 24SA?
Does anyone know where the house charger /converter is located on the Thor Citation Chateau Sprinter 24SA?
I'm planning to replace it with an inverter/charger and can't seem to find it.
dirtyguy is offline   Reply With Quote
Old 02-08-2013, 04:09 PM   #2
aljimenez
'13 LTV Serenity on '12 3
aljimenez's Avatar
Default Re: House charger location on Citation Sprinter 24SA?
Don't know for sure, but it should be behind where all the fuses are located. It typically is a metal brown box with a piano hinge to open the top part revealing circuit breakers and fuses for the coach side of things... Al
Old 02-08-2013, 07:38 PM   #3
dirtyguy
That makes sense, thanks. I will check behind there tonight.
Old 03-29-2013, 12:01 AM   #4
jgoodn
Question Re: House charger location on Citation Sprinter 24SA?
As a related question, I am looking for the Battery isolation controller on my 2011 Four Winds Siesta / Freightliner sprinter.
My coach batteries do not charge from the alternator with the engine running. They only charge from external 110 VAC and the generator. According to the Four Winds Siesta manual the Battery isolation controller automatically performs this function. Where is it and does it have an on/off switch or could it be missing or defective?
jgoodn is offline   Reply With Quote
Old 08-07-2016, 02:40 PM   #5
thomasd923
my 2011 charges off the alternator. The battery isolator to charge off the converter is behind the fuse/charging panel aside the drawers (brown plastic). It won't charge unless you connect the coach batteries via the rocker switch
thomasd923 is offline   Reply With Quote
Old 09-04-2019, 04:48 PM   #6
Mailman1044
So. Is it possible to make the house batteries charge off the engine alternator?
Sure would be nice. I was really surprised to find the 2015 i just bought didn't charge when driving.
Mailman1044 is offline   Reply With Quote
Old 09-05-2019, 03:36 AM   #7
Hooligan2
Hooligan2's Avatar
Mailman- You have responded to a post from 2016... But welcome..
I have a Thor Siesta 24ST- The Coach batteries are charged by the converter when plugged into the 120 volt. They should also be charged by the alternator when the engine is running. Check the USE/STORE switch , usually in the step well.
The chassis battery is usually not charged when on shore power.
I believe the Winnebago Sprinter models are wired differently and do charge the engine battery on shore power.
Pensacola, Fl
2016 Siesta Sprinter 24ST
George the Newfoundland, Lily the Pug
1972 Moto Guzzi Eldorado
Hooligan2 is offline   Reply With Quote
Old 09-08-2019, 02:13 PM   #8
Mailman1044
Thank you for your response. I'll see what I can figure out.
I'm pretty sure the alternator isn't charging the house batteries.
Old 09-08-2019, 08:13 PM   #9
Hooligan2
Hooligan2's Avatar
Check the use/store switch.. If it is off the coach batteries are not connected.. at all... Easy check with engine off and you are not plugged in to shore tie do your 12 volt coach cabin lights work. They won't if use/store is off..
Pensacola, Fl
Old 09-17-2019, 01:50 PM   #10
kylecm
You are correct. Unfortunately, the Thor Siestas chassis battery will only be charged from the chassis alternator. If the chassis battery is dead there is no way to charge it from the coach. I keep a 20' set of jumper cables just in case I need to jump the chassis from the coach.
The alternator will charge the coach batteries through the Isolator Solenoid (I think mine is under the driver's seat).
kylecm is offline   Reply With Quote
