Old 11-21-2019, 06:42 PM   #1
123indyrt
Default 2013 def light and count down starts
HELP. New to sprinters. 2013 3.0 DEF fluid got low. I read it requires min of 2.0 quarts, i put in 2.5 light still on and the start count is still going down. ive cycled it 3 or times and driven it to no avail. im down to 2 or 3 starts.
ps i also read it will allow up tp 1000 mi?? that counter started at "500mi" it has now been at 900 for a minute
HELP
Ronnie
123indyrt is offline   Reply With Quote
The Following User Says Thank You to 123indyrt For This Useful Post:
Sinatorj (11-23-2019)
Old 11-21-2019, 07:01 PM   #2
elemental
Default Re: 2013 def light and count down starts
The Sprinter DEF fluid tank capacity is measured in gallons, not quarts. Data generated from this forum suggests that waiting until the "fluid low" warning is risky, as your experience confirms. The low warning doesn't go off until the reservoir is significantly depleted, and exposing sensors in the reservoir may allow urea crystallization and affect subsequent sensor operation.
If you have only added 2 1/2 quarts (about 1/2 gallon) then as a first/easy action to fix your problem you should FILL the DEF reservoir. This will probably take a number of gallons (the DEF tank on my 2017 is just over 5 gallons in capacity - I don't know what yours is).
Hopefully others will chime in with ideas about how to deal with "low starts" assuming that simply filling the DEF tank doesn't work.
2017 Sprinter 2500 170 Crew OM642 5-speed auto with Adventure Wagon interior&MOAB
elemental is offline   Reply With Quote
Old 11-22-2019, 04:55 AM   #3
123indyrt
my error. I DID put 2.5 gallons in the def. Ive since topped it off, disconnected the interior power cable, disconnected the under hood computer to no avail. only did key forward did not start it tho. same codes. def sign and says 900mi
Preeetty sure im gonna ship the computer out. My buddy did. works great
Old 11-22-2019, 09:55 PM   #4
pfflyer
pfflyer's Avatar
Is your check engine light on as well? If so, I hate to tell you it is most likely a trip to the dealer. Does "ship the computer out" mean you are getting it tuned? What company? I didn't know there was a reliable one for a 2013.
Full time cargo part time camper.
My convertible Sprinter http://sprinter-source.com/forum/showthread.php?t=39367
2013 long tall convertible crew van used for work now
2016 Jayco Melbourne 24K Class C on 2015 Sprinter chassis
pfflyer is offline   Reply With Quote
The Following User Says Thank You to pfflyer For This Useful Post:
sailquik (11-23-2019)
