Go Back   Sprinter-Forum > VS30 Sprinters > VS30 Database
VS30 Database Reference Information, Part Numbers, Recalls, TSBs, and etc.
Old 11-18-2019, 11:19 PM   #1
mcjohnson5174
Default VS30 Under Seat wiring Diagram F150/1, F150/4, F150/5, EK1 Goal Zero Yeti Charging
I made a couple diagrams that I think might help others...once I get this figured out I will make a final one.
First here is a quick ref for under the seat
Second here is the F150/1 labels. Guys have said to tap off there. Not super sure on these, but I think so. The open spot is #2, seems like a logical tap, but it isn't hot. Needs a bridge/jumper?
F150:1 diagram.jpg
Or could just screw on to top terminal of battery too?
Here is the F150/4. Read a lot about this location, just not any useful instruction. The Fuse Assignment Supplement 2018-11 does not appear to be accurate. I heard there is another one?I have a 2019 4x4 and this supplement was included in my stuff, but does not appear to match up. I just focused on 1-7 as I think this appears to be a logical place to tap. No idea what, if any fuses are attached? Why not tap in here? If so, where?
F150:4 diagram.jpg
F150:4 supp pg.jpg
For lower voltage...there is the EK1 also..
Im trying to achieve two things:
1. Tap the Goal Zero Yeti alternator charger
2. Tap for a fuse panel when GZ is not in van.
Thanks
Matt
Im in Minnesota, and have yet to find a knowledgeable pro within a days drive. For all of you that are in areas that have them, consider yourself lucky.
mcjohnson5174 is offline   Reply With Quote
The Following 3 Users Say Thank You to mcjohnson5174 For This Useful Post:
autostaretx (11-19-2019), Egb (12-04-2019), JFC (11-25-2019)
Old 11-19-2019, 12:19 AM   #2
autostaretx's Avatar
Default Re: VS30 Under Seat wiring Diagram F150/1, F150/4, F150/5, EK1 Goal Zero Yeti Chargin
Thanks ... does the F150/1 stud (2) that you've attached "my cable" to attach to anything, or is it just embedded in the block's plastic?
...and probably a follow-on question is what/where does the "battery sensor (1)" stud go?
Are both of those just bus-barred to the battery +, simply out-of-sight?
nice photos...
Old 11-19-2019, 02:48 AM   #3
mcjohnson5174
Stud 2 & Stud 1 just appear to be embedded in the block plastic. Good question about simply out of sight. Curious to why some would be embedded and others connected through surface mounted plates?
Old 11-19-2019, 04:27 AM   #4
dynaco1
dynaco1's Avatar
Studs imbedded in plastic are probably the provisions for the far end (down stream) of the Fuse termination. Install fuse and land cable lug here??
dynaco1 is offline   Reply With Quote
