#11 |
2015 CS Adventurous
Thanks for all of the input. I have another question. Does disconnecting the battery disconnect next to the floor pedals have the same effect as disconnecting the negative battery terminal from the actual engine battery beneath the pilot's floor? i.e. supposedly reset the system?
#12 |
2013 Itasca Reyo 25R
Yes. This is the connection for the negative battery cable.
2013 Itasca Reyo 25R |
The Following User Says Thank You to TJLee089 For This Useful Post: | manfromwahoo (11-07-2019) |
#13 |
2018 Wonder FTB
If you don't have anything directly connected to the battery positive. Scarecrow is working an issue where maybe that happened. As he told us when we picked up his rig in SLC the disconnect was engaged but the chassis battery was still quite dead. He suspects the installation of the new radio unit might be the culprit as he already replaced the chassis battery once. I know from my own experience that disconnecting at the gas pedal resulted in exactly the result wahoo expects. If you haven't had anything new installed on can assume the disconnect actually disconnects!
Kelly Rio Verde and Show Low AZ 2018 Wonder FTB https://cuernoverdesolar.wordpress.com/ |
#14 | |
Not sure exactly what you mean, but if the battery negative is truly disconnected, there can be no current and it doesn't matter if anything is directly connected to the battery positive.
#15 |
2018 Wonder FTB
Yes, that is correct. What I meant was that if you use the positive disconnect by the gas pedal in the cab you may or may not get all the loads disconnected. If you disconnect the negative at the battery you most certainly get all the loads disconnected. Sorry for the confusion.
#16 | |
2015 LTV IB: 2015 3500 V6
![]() Quote:
Mike "Free advice is worth what you pay for it. Sometimes.." Last edited by mikeme; 11-09-2019 at 02:59 PM. Reason: Accentuate the positive |
The Following 4 Users Say Thank You to mikeme For This Useful Post: |
#17 | |
As Mikeme implied, there is no need to ever disconnect the negative at the battery unless an additional negative lead has been added there.
The Following User Says Thank You to TJLee089 For This Useful Post: | manfromwahoo (11-09-2019) |
#18 |
2015 CS Adventurous
Problem solved. As it turned out, a new multimeter showed me that my brand new 1.5 amp Schumacher charger/Maintainer was defective. So, I returned the defective 1.5 amp and bought a 3 amp Schumacher. Hooked it up to the contacts under the hood and 15 hrs later the ignition freed up. Finished it off through the cigarette lighter.
Thank you all for your help. A real learning experience for me. |
#19 |
2018 Unity MB
Multimeters are nice to have. We carry one on the road. Great for troubleshooting, making sense of things, not just from voltage measurements. I have been able to diagnosis blown fuses that did not look blown and an AC breaker that had failed.
The Following User Says Thank You to woundedpig For This Useful Post: | manfromwahoo (11-13-2019) |
#20 | |
![]() Quote:
Bob |
The Following User Says Thank You to woodywesty For This Useful Post: | manfromwahoo (11-13-2019) |
Thread Tools | |
Display Modes | |
