Old 11-06-2019, 12:50 PM   #11
SSTraveler
2014 LTV Unity Murphy Bed
SSTraveler's Avatar
Default Re: OEM solar panel blew off
Ablock, You may want to consider tilt mounts. I have also consider using the Renogy Tilt mount brackets for future panel installs, https://www.renogy.com/rv-tilt-mount-brackets/ since they would give you more options for use and maintenance. I would use the 5952 VHB tape to stick them to the roof, should be very strong since there is a lot more surface area, and then cover with eternabond tape for extra strength insurance. You could also cover with Dicor but I think using Eternabond tape is easier and cleaner, plus you don't have to wait 5 days for setting. I like the idea of these tilting brackets because they do have a lot of roof adhesion surface area (so no need to drill more holes) and you can tilt them up to clean underneath the panels, especially during pollen season or to remove leaves and pine needles (excessive where I live). Also you can angle the panel to get more sun during the winter. It seems the tilt mounts make for an easy install, no new holes, and give you more flexibility to use and maintain your panels and roof.
SSTraveler
Old 11-06-2019, 03:01 PM   #12
harrysalit
2019 Wonder FTB
harrysalit's Avatar
Here is a source for wireless tilts,
https://www.solarvector.net/
harrysalit is online now   Reply With Quote
The Following User Says Thank You to harrysalit For This Useful Post:
Boxster1971 (11-06-2019)
Old 11-06-2019, 06:08 PM   #13
Larry M
I installed our 2-100 watt panels using 35mm Rocker Foot mounts from AM Solar. I needed the clearance because of the curvature of the roof and I can also easily check the roof seams. They come with VHB tape already. I did add some screws for piece of mind.
https://amsolar.com/rv-solar-panel-k...ng-accessories
Larry M is offline   Reply With Quote
Old 11-06-2019, 07:33 PM   #14
Klipstr
2018 Wonder FTB
Harry,
Those can't be cheap! One would have to harvest a bunch more power (and not have enough with flat mounted panels ) to pay for those...
Kelly
Rio Verde and Show Low AZ
2018 Wonder FTB
https://cuernoverdesolar.wordpress.com/
Klipstr is offline   Reply With Quote
Old 11-06-2019, 09:40 PM   #15
gltrimble
Default OEM solar panel blew off
My six Renogy 100 watt panels are hinged on one side. I did this primarily for maintenance. In most cases the benefits for solar production with tilting panels are minimal and hardly worth the effort of climbing up on the roof. You are better off investing in more panels.
gltrimble is online now   Reply With Quote
The Following User Says Thank You to gltrimble For This Useful Post:
Klipstr (11-07-2019)
Old 11-07-2019, 01:57 AM   #16
harrysalit
2019 Wonder FTB
harrysalit's Avatar
Klipster, I think under $200 when I looked at them a year ago, don’t about now.
Old 11-07-2019, 03:51 PM   #17
Klipstr
2018 Wonder FTB
Each? That more than doubles the cost of the panel and probably for maybe 20% output improvement.
Kelly
2018 Wonder FTB
Old 11-07-2019, 04:09 PM   #18
harrysalit
2019 Wonder FTB
harrysalit's Avatar
Look how impressive it would be arriving at camp, push a button, panels go up!
Did you park in the right direction?
Cheaper than the cost of falling of the roof!
Klipstr (11-12-2019)
Old 11-26-2019, 06:45 PM   #19
ablock
Finished the repair yesterday. I'd had good luck with the AM Solar mounts so I just purchased them again for the Renogy panels. Fitment requires drilling four corner holes in each panel but that's not a big deal.
When I installed the first set of 4 panels using VHB tape on the AM Solar mounts, the roof was brand new. Now it isn't, so in addition to the VHB I coated the mounting feet and foot/roof joint in Dicor.
Thanks all for the suggestions.
Old 11-26-2019, 07:18 PM   #20
msmolow
2019 Unity CB / 2018 Chas
If you're using Dicor to protect the mounts from surface water, that would work. Dicor is not an adhesive and shouldn't be used as such. Sikaflex or 3M 5200 are two examples of adhesive products.
msmolow is offline   Reply With Quote
