View Poll Results: Is Butcher Block Too Heavy for a Countertop??
Yes 14 51.85%
No 13 48.15%
Voters: 27. You may not vote on this poll | Withdraw Vote
Old 09-27-2019, 02:05 AM   #1
travisap
Default Is Butcher Block Too Heavy for a Countertop? 66x22
Purchased a 2' x 8' x 1.5" piece of butcher block today... man it is heavy! It would be cut to a smaller size, shaving off some weight. What would allow for a similar look/feel/function without all the weight?
'08 Dodge Sprinter 144WB HighRoof 30K
travisap is offline   Reply With Quote
Old 09-27-2019, 02:55 AM   #2
wankel7
Default Re: Is Butcher Block Too Heavy for a Countertop? 66x22
I found some good looking maple 3/4 plywood and covered it in epoxy resin.
My counter top is the same dimms.
wankel7 is offline   Reply With Quote
Old 09-27-2019, 03:22 AM   #3
marklg
You could go to town with a 2' wide planer!
I would think that you should be able to find thinner butcher block. We got maple stair treads made out of multiple boards that are thinner, but smaller dimensions otherwise. I made two tables out of 3/4 thick maple butcher block cutting boards that were available from Bed, Bath and Beyond. They do look nice, bu they don't sell them any more. I did scratch one up though on a metal screw head, damn!
Regards,
Mark
marklg is offline   Reply With Quote
Old 09-27-2019, 06:34 AM   #4
Boathik
Future van builder
I have a teak butcher block counter roughly 69x22 with a 24 apron sink. I saved weight by building the cabinet from 12mm Baltic birch plywood.
Boathik is offline   Reply With Quote
Old 09-27-2019, 08:38 PM   #5
Kevsuda
I used Ikea birch butcher block. Mine is only about 52" if I remember correctly and I also trimmed a couple inches off the depth, but made that into the backsplash. It is heavy, but any substantial countertop is going to be heavy. This was one of my weight splurges. The galley cabinet it sits on is made from 1/2" ply (technically less) and is designed without a bottom sheet or back sheet. It's heavy, but when you compare to your alternatives, I think you find you are only talking a relatively few pounds difference to most other common counter top materials.
Kevsuda is offline   Reply With Quote
Old 09-27-2019, 08:51 PM   #6
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
If you are that concerned about the weight then rout out some areas underneath where it will not show. If you leave maybe an inch of thickness then that should probably be sufficient strength left.
Keith.
36,000 miles from New
The Following 3 Users Say Thank You to Cheyenne For This Useful Post:
BrennWagon (09-28-2019), Midwestdrifter (09-27-2019), ranchworld (09-29-2019)
Old 09-27-2019, 09:53 PM   #7
Its all about the total weight. If you have capacity to spare, feel free to use it how you like. Many full featured conversions are very heavy if materials like that are used everywhere.
Old 09-28-2019, 06:20 AM   #8
HighPockets
In '91 I bought a Honda CRX-HX as a commuter vehicle. It was the high mileage version of the CRX line. I was amazed at the trouble they went to, to achieve the HM. They made aluminum castings to replace stamped steel items used in the other two models among other things. Since then I have been super conscious of the relationship between weight and fuel mileage. If it isn't necessary it's not included. If I can get a lighter version (still of good quality) I use that. If I can use thinner wood and get the strength by good design and the use of glues I do that. The designer of my boat, SkiffAmerica 20, was an ultra-light aircraft fanatic. He designed the boat using the same principles. It will sleep 3 people and do 27 mph with a 30 hp outboard. The only problem is it has such a shallow draft that the wind pushes it around too easily at slow speeds. And it's not just fuel mileage it also affects performance and road handling.
Gene
P.S. At one point (1982) I traded a Honda Gold Wing that weighed 700 lbs. for a BMW R80/GS that weighed 375 lbs.
'07 CRD 144" high top, Koni Reds, Hellwig stabilizer bar, 276K miles, new paint, Pioneer SS with two amps, 11 speakers, at work on RV build-out.
HighPockets is offline   Reply With Quote
Old 09-28-2019, 07:38 PM   #9
glasseye
glasseye's Avatar
Prolly the best Beemer ever built. I hope you still have it.
"Frito" : the potato chip truck. 04 Hi-Roof 140 cargo.9800 miles by PO
150K miles in 10 summers. Fuel, filters, oil, tires, bulbs, batteries, front brakes, serp belt and tensioner, upper charge air hose, Cyl 3 failing GP.
Accompanied and assisted by "Cheeto", a 2019 Rad Powerbikes Rad City Stepthrough.
"Travels With Frito" Global travels by van, motorcycle and other www.petercmclennan.com
Absent this forum, I'd never have bought a Sprinter.
glasseye is offline   Reply With Quote
The Following User Says Thank You to glasseye For This Useful Post:
Old 09-28-2019, 08:27 PM   #10
HighPockets
I do. Unfortunately, it has played 2nd, 3rd, 4th, 5th fiddle to the boat build, bathhouse build, 3rd bathroom build, the yard, my Sprinter van build, not to mention I own a farm and have in-laws that I owe so much to that are in their nineties. Actually, my F-I-L died this summer and his widow is very lonely so my wife and I try to spend some time with her every day. To sum that up it doesn't run and hasn't been ridden for about 10 years.
I am old enough that I now wish I had many things I sold off cheap. Now it's not a question of whether to sell it or not but who to bequeath it to in my will.
Gene
