grantwilson
FreedomVanGo
As always, 100% transparent with my builds that roll out, so heres another one! EV3 is shortly after on a 170 2019 2wd
Untitled by Grant Wilson, on Flickr
Interior color selection.
Walls
Floors
Countertop
Cabinet faces are the white scroll pattern, and sides and bottoms are white
White powdercoat
BFG 285/75-16
Gotta pull the mudflaps and no issues. They do rub on the flaps
Buildout includes:
200 watts of Renogy solar
Adventure Wagon RUV Interior Kit :
Electrical – A complete wiring harness and accessories to power the van cabin. The fully assembled and loomed harness connects to the stock Sprinter battery and includes leads for two fans, six lights, four UBS ports, four 12v ports, and two accessories (heater, sink, etc.). The included LED lights are dimmable and can switch to red. The eight included power ports are marine grade. All installation hardware is included and all wire ends connectors are installed.
Insulation –Hushmat sound deadener, 3M Thinsulate wall and ceiling insulation to match the Sprinter interior cavities, and double-sided tape for installation. All interior panels also have reflectix installed on the backside for added sound and heat insulation.
Ceiling Fans – Two Maxxair ceiling fans, with mounting base, trim ring, weather seal, electrical connections and installation hardware.
Wall and Ceiling Bracers – Powder-coated, pre-assembled bracers used for L-track installation points and to support our optional bed and storage systems. Includes all hardware.
L-track – Aircraft-style L-track pre-cut and pre-drilled. Four (144WB) or six (170WB) vertical wall tracks, four horizonal wall tracks and three ceiling tracks with mounting hardware.
Wall and Ceiling Panels – Cut-to-fit 6mm marine-grade, plywood panels, upholstered in your choice of 4 standard fabric colors, and backed with Reflectix insulation. Pre-drilled for mounting power outlets. Ceiling panels are cut out for fans (if needed) and the six LED lights are already installed. All installation hardware is included.
Molded Trim – Custom-made, upholstered interior panels to complete areas above sliding door, behind driver’s head, and driver’s side crew window. Mounting hardware included.
Luxury Vinyl Plank Flooring
Under Floor Insulation
Aluminum Framed Interior Components:
Wheel well covers with hinged lid
Queen Bed Platform, north to south
Fridge slide mounted cabinet with drawer
Galley Unit with 3 drawers, 2 doors
3 Upper Cabinets (exchangeable for Soft sided Upper Cabinets)
Laminate cabinet doors, sides and bottom
Galley includes:
Plug and play to a 12v source
Dometic Sink and Stove Combo
Water Pump
1lb Propane Tank holder
All Plumbing and propane regulator
12v Water pump
2 5 Gallon Tanks
Quick Disconnect for water tank
Switch for Water Pump
Ability to mount Lagun table already engineered, just add table and mount
Dometic CFX50 Fridge unit
Dometic CFX50 Slide
Alpine Mechanism Seat Swivels where applicable
AMAuto OEM Style Bonded Sliding Passenger window with screen
Ctek DC to DC charger under driver seat
Ctek Bluetooth Battery Monitor
100AH Renogy AGM Battery under passenger seat, optionally in engine bay (required for heater installation)
All Marine grade wire, heat shrink terminals
Upgrades:
Flarespace with tern window
BFG Tires
Owl Vans Tire carrier and Sherpa
Goal zero yeti 1400 with vehicle integration wiring
Walls
Floors
Countertop
White powdercoat
BFG 285/75-16
Buildout includes:
Galley includes:
Water Pump
12v Water pump
2 5 Gallon Tanks
Dometic CFX50 Slide
Upgrades:
BFG Tires
