Old 11-08-2014, 08:06 PM   #11
grozier
Default Re: Replacing GFCI / residual current interrupter
You could in theory replace all the DIN rail breakers with a US style system, but it would be cheaper to get a euro RCD shipped over. It just needs to be 30mA and 30A+. See for example http://www.amazon.co.uk/Residual-Cur...sidual+current
Better yet is for ABB to stand by their product!
It is very important that this breaker be as far "upstream" as possible; putting GFCIs at each outlet does not achieve the same effect. Not sure about the US, but most sites here also have an RCD built into the power box you connect to.
Interestly, our van (#121) has a regular, non-GFCI outlet in the back.
Ted
Old 02-13-2015, 11:59 PM   #12
MrTomacco
Mr. Tommaco
Still no replacement breaker/GFCI/RCD from ABB. 16 weeks and counting. The local rep did get in touch with ABB again the ABB guy said "He apologized for the way this issue has been handled and informed me he has taken the issue on himself". They have my defective unit so I have no 110 VAC in the camper. Once I actually get one, we should get together for a mass request. It will get their attention better and justify a production run. Supposedly they are made on order individually.
Rob
Old 02-16-2015, 08:55 PM   #13
MrTomacco
Mr. Tommaco
Success! I picked up the replacement ABB GFCI/RCD today! However I can't find the copious number of photos I took to document the wiring. I would appreciate posting clear photo/s showing the wiring on the top of the breakers and the bottom of the breakers.
Old 02-16-2015, 09:41 PM   #14
MrTomacco
Mr. Tommaco
I finally have received the replacement GFCI/breaker/RCD after several months! Removal and installation is not trivial as a hidden connector must be removed and modified and an additional 8 gauge wire added. I will write up a procedure for you or an electrician to follow as this is 110 volts and many may not feel comfortable doing it them selves.
I believe the most efficient way would be a group request for return merchandise Authorization RMA from ABB. I would think dozens of individual requests spread out over months could delay the process. It took several months to get my replacement after I sent my defective unit in, hopefully they could be convinced to ship replacements prior to receiving the defective units so the Westy's would not be out of service and the removal and replacement could happen at the same time in one electrician visit.
I created a database on the Yahoo site for those with defective GFCIs interested in getting a replacement. Is there some way to make a list on this site for those not on the yahoo site also? Once I get an idea of how many replacements are needed I will contact ABB and see how they want to handle them.
Rob
#128
The Following User Says Thank You to MrTomacco For This Useful Post:
onemanvan (02-17-2015)
Old 02-16-2015, 09:53 PM   #15
discus
GA Westy
Default
Im in. How do i sign up?
Old 02-17-2015, 12:23 AM   #16
MrTomacco
Mr. Tommaco
Best way would be on the Yahoo database https://groups.yahoo.com/neo/groups/...tabase/66/edit
unless some one can do a similar list here.
Rob
Old 02-17-2015, 01:10 AM   #17
Ted/Rob: Thanks for tracking all this info down. As there were about 250 Westies imported into the US with 120 volt circuit breakers, would think that would be a good number to target.
Would think that ABB could get together with Airstream to get the exact number count. Airstream should have the names of all the original owners and subsequent owners could be identified by their VINs if their Sprinters were ever serviced by a dealer (Probably too much to hope for.).
If you could post contact person at ABB for voluntary recall, etc., that'd be great. Yahoo Groups doesn't work for me ever since their update.
Old 02-17-2015, 01:15 AM   #18
Oh, it'd be nice if I didn't have to remove and wait for replacement. If ABB requires proof of ownership of a Westy, could send copy of registration. Or could do a refundable deposit or something with ABB--return original one after new one installed.
As of now, am not about to touch or test GFCI breaker--otherwise, might lose 120 volt circuits.
Old 02-17-2015, 07:15 AM   #19
MrTomacco
Mr. Tommaco
I don't think Airstream can be of much help to us orphans. Not many are still owned by the original owner. It is not a NTHSA safety recall. I don't know if 100% are bad, I remember some posts saying theirs worked. If you don't Yahoo, just post here so I can let ABB know what's coming..
Old 02-17-2015, 04:27 PM   #20
MrTomacco
Mr. Tommaco
For laughs, I searched ebay for the breaker, there was a surplus place listing it as less than $10!!
http://www.ebay.com/sch/i.html?_odkw...F0.03&_sacat=0
BE SURE YOU GET THE EXACT PART NUMBER THAT TED LISTED ON THE FIRST POST!!
Rob
