Mr1987joker
Hello,
Newbie to the Sprinter Westfalia. I have number 43 of the series. When my van is parked and it has rained, water will leak from the A pillar once the van first moves. When the brakes are applied water leaks on the inside from the A pillar where the interior seam is located. The seam where the plastic headliner and the door A pillar come together. The water drips on the door window switch area. I've read the forum where other people have had the same problem, but I haven't read a solution. I have replaced the large skylight and the bathroom skylight to deal with broken skylights and water leaks. I fixed the water leak from the large skylight. While fixing the skylights I checked all the sealant on the roof that was obvious. I'm thinking maybe the TV antenna mounting screws or the AC lines. Water only leaks from the A pillar either drivers or passengers side. If you have had this problem and found a solution please let me know.
cheers,
brennan
cheers,
brennan
