Hi everyone! I'm selling my 2015 Ram Promaster 2500 ecodiesel (159'WB) conversion van with just over 21K miles! Located in Orange County CA. Also listed on Orange County Craigslist
https://orangecounty.craigslist.org/rvs/d/2015-ram-promaster-2500/6390017272.html
A detailed spec sheet and a walk through video available upon request for serious inquires ONLY. Thanks for looking! - Tricia
Contact Info:
Tricia Hax
315-430-5996
tricia.hax@gmail.com
Regularly scheduled fluid changes: oil, DEF, windshield washer fluid
State Farm Insurance with additional coverage
NYS Registration and Inspection
Van Build:
Reflectix insulation on interior surface of entire van
Framed the interior with 2x4's, like a house
R-13 insulation behind walls
Finished with pine tongue and groove 5/16in x 3 11/16in, white washed with two coats, water based polyurethane clear finish (minwax)
¾" plywood subfloor
Linoleum wood print floor
74 ¼" interior height
Custom countertops & cabinets
Bed Platform: 51" wide, 3 ¼" deep, 71" long
47" wide opening underneath, 57" deep, 28 ¾" clearance from floor to bottom of platform
Black out curtains
5 vintage wall baskets
paper towel holder
110V GIF outlet
LED light switch
Ziebart undercoat
VanTech rear access ladder for high roof vehicles (83")
Yakima Roof Rack System with 86" roundbars and control tower sliding system
CURT 13170 class 3 trailer hitch
Passenger side swivel seat
Webasto Air Top 2000 STC diesel heater
Solar System
(2) 100W Renogy monocrystalline solar panels
(2) 155amg VMAX Solar 12V deep cycle batteries
Renogy View Star 20AMP PWM solar charge controller with LCD display
500W Renogy Inverter
WFCO 8935 35amp power center
2000W Renogy Inverter
110V offshore power capabilities
Car battery connected to the solar batteries for charging while driving
(6) 110V outlets, 1 with USB ports, 1 extra for access to wires.
(9) 3W warm white recessed LED lights in pine ceiling
(4) 3W warm white recessed LED lights under overhead cupboard
Fan-Tastic Vent 807350 12V variable speed reversible ceiling fan
30 gallon fresh water tank
SHURFLO water pump, 12V
Ph7 single handle pull down spray kitchen sink faucet, brushed nickel
Kraus 23inch under mount single bowl 16 gauge stainless steel kitchen sink
Camco flexible camper drain
5 gallon plastic water can- grey water holding tank
Atwood 52272 21" Wedgewood 3-burner range, stainless top/front
Atwood Wedgewood stainless steel bi-fold top cover/back splash
3.1 Cu. Ft. Edgestar Fridge/Freezer (CRF321SS)
11lb Worthington prograde propane tank
Mr. Heater 15ft propane appliance hose
Contact Info:
Tricia Hax
315-430-5996
Van Build:
¾" plywood subfloor
Black out curtains
paper towel holder
110V GIF outlet
LED light switch
Ziebart undercoat
Solar System
