I clipped the edge of a carwash hanger bracket with one of my top, front clearance lights breaking the housing and shorting out the fuse (light housing was crushed and shorted to ground). I purchased another clearance light, installed it, but can't find the fuse to replace it.
I have searched all the locations and fuses mentioned in the owners manual (I've seen zero fuses marked "clearance or head lights in the manual...?)
The fuse box located under the driver's kick panel, under the seat (I removed seat to see if there might be more fuses in there besides the one under the seat panel) and the book clearly shows that the fuse box by the battery doesn't hold any of the fuses I'm looking for.
Used a test light to check ALL my fuses individually and they all test good...
Looked in the engine compartment too..!
Manual tells you to go to the dealer if your "dash warning light" comes on, but how hard is it to change a fuse if you know where it's located...? Any help appreciated to avoid going back to the dealer until my engine dies again.
Thanks
Thanks
