Reply
Old 10-12-2017, 03:30 AM   #31
Jbernielh
Default Re: DPF sensor
thats probably a little confusing..
not my invoice, but the copies plmbst posted from having his replaced..
I just replaced mine, along with the new connector and put clamps at all locations.. I'd post pictures for you Bob, but I've never figured out how to do that..
I'm trying to figure out if theres a bulletin somewhere that indicates which items need to be taught into the computer when they're replaced..
Bernie
Jbernielh is offline   Reply With Quote
Old 10-12-2017, 04:42 AM   #32
Bobnoxious
Exterminate Islam
Bobnoxious's Avatar
Originally Posted by Jbernielh View Post
thats probably a little confusing tubing installation ..
Bernie
Thank you about the thought of posting pictures Bernie. Curious how the undersized tubing installation went?
Old 10-12-2017, 05:59 PM   #33
Bobnoxious
Exterminate Islam
Bobnoxious's Avatar
Bernie
Hi Bernie:
Here's some info from WIS. It appears the differential pressure sensor requires initialization (I'm assuming also referred to as a teach-in? I'm still learning so maybe others can confirm?).
Also, the picture of differential pressure sensor assembly is fuzzy but it does appear there are clamps common to the pressure sensor and the hard pipes four (4) clamps total. NOTE: "AR" is TESTING AND REPAIR. Good luck, NOX
Old 10-13-2017, 01:47 AM   #34
Jbernielh
thx for the info Bob
from the looks of it I'd say your right, but isn't the engine listed the 4 cylinder.. but then I can't imagine it would make any difference 4 or 6.. I'll just take the RV to the shop and have them plug it in and see what happens..
in regards to the hose issue we discussed earlier... well, lets just say laziness trumps (is it okay to use that word here) good practices any day.. I looked at the 2 hoses at the sensor and they were both flexible and good shape.. couldn't really tell the difference between the installed ones and the new, plus, installing them on the new sensor they both required a good push to get them on the spigots.. but I put clamps on them just the same..
thx again
Bernie
The Following User Says Thank You to Jbernielh For This Useful Post:
Bobnoxious (10-13-2017)
Old 10-13-2017, 01:51 AM   #35
plmbst
No clamps at the sensor end on my replacement.
2013 144" Cargo in Jet Black
plmbst is offline   Reply With Quote
Old 10-13-2017, 01:55 AM   #36
Bobnoxious
Exterminate Islam
Bobnoxious's Avatar
Shame on you! Probably not a big deal until the tubing ages and becomes brittle but by then it may be time for a new Sprinter?
Reply
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
