Old 02-14-2020, 06:01 PM   #1
Capnkev
Default DPF failure at only 22,000 miles?
We just bought a 2016 Sprinter that was converted into a 2017 Pleasure Way Plateau TS. It only has 22,000 miles on it. While driving it home from North Carolina to Florida, the Check Engine light came on and then the ESP light, and a bunch of other alarms and messages. Took it to the Mercedes dealer in Jacksonville. They said the wheel sensor was bad, and that the DPF failed and melted some wiring and needs to be replaced. Anyone have any insights on what would cause a DPF to fail on a vehicle with such low mileage? Also, how common is it for wheel sensors to fail? Iím worried maybe I just spent big money on a lemon. Iím having the 20,000 mile service done and replacing pretty much every fluid and filter, just to start fresh before we head up to Alaska this summer.
Capnkev is offline   Reply With Quote
Old 02-14-2020, 06:11 PM   #2
lindenengineering
Default Re: DPF failure at only 22,000 miles?
OK this is an easy one ask me another!!!
We have seen a lot of 2016 's abnormally bust the DPF flex pipe for some reason scorching the wiring harness to the transmission.
We simply replace the flex pipe by welding in a new one and fabbing the ends.
Then repair or replace the harness as needs must!
Dealer will replace the whole thing, but the Cat mounting plate MUST be checked for fracture as the whole shooting match will be doing the samba under the the van when underway.
All the best
Old 02-14-2020, 06:24 PM   #3
Kajtek1
Just to make it clear - the DPF broke, not failed to filter?
MB makes fine vehicles and only DPF & DEF - being new technology has some baby teeth.
Enjoy Alaska. We did it last summer, who turned to be summer of Century with whooping 72F weather.
Kajtek1 is offline   Reply With Quote
Old 02-14-2020, 06:41 PM   #4
Capnkev
All the best
Thanks Dennis! Thatís great info. Iíll pass it on to the dealer. Really appreciate your time and response
Old 02-14-2020, 06:42 PM   #5
Capnkev
Yes, they said it needed to be replaced.
Old 02-14-2020, 08:22 PM   #6
JFM
You are most probably still under emission system warranty; validate with dealer first. If they say "no", find the warranty book in the glove box and start arguing with them...
JFM is offline   Reply With Quote
The Following User Says Thank You to JFM For This Useful Post:
Capnkev (02-14-2020)
Old 02-14-2020, 08:58 PM   #7
CJPJ
2008 3500 170"ext. 3.0 V6
CJPJ's Avatar
Hi Capnkev. The DPF failure is because a support bracket breaks. Somewhat common and there is a cure by Remove and Replace with a MB revised bracket. The melted wires is a result of the broken bracket letting hot exhaust out. The new bracket will prevent a recurrence.
The wheel speed sensor failing isn't too common but happens and is a simple repair
Old 02-14-2020, 09:09 PM   #8
Capnkev
Thanks! Thatís good to know. I appreciate you taking the time to help me.
Old 02-15-2020, 12:02 AM   #9
lindenengineering
Just got yet another in today.
The flex pipe totally gone.
Hot gases scorched the DEF injector and wiring, put on the Mil lamp and then got the countdown.
Guy get yours checked !
This one should be good with a flex repair , new DEF injector , and a harness repair .
All makes work for the working man to do!
Old 02-15-2020, 12:51 PM   #10
Bobnoxious
Picture???
1226dslsimmons (02-16-2020)
dpf
