Old 02-07-2020, 12:20 AM   #1
HopTripSploot
Question Is it worth buying a 2010 that just had the DEF system repair?
I'm going to see this van (2010 170ext 2500 122k mi) on Saturday and the owner indicated he just dumped 10k into it.
"Everything got done from DEF system to windshield, brakes, you name it" - Exact quote.
I'm wondering if the required DEF system repair indicates there might be other issues down the line or if having that done means I simply need to properly maintain with top of the line DEF to keep things working smoothly.
Is there anything specific I should look out for or ask after? I know 2010 is the first year MB used Bluetec and that there have been issues reported with the EGR valve so I'll be checking if the EGR was replaced recently (as well as the NOx sensors)
So if you had to give a thumbs up or thumbs down to a vehicle with a DEF system repair which way would you lean?
HopTripSploot is offline   Reply With Quote
Old 02-07-2020, 12:24 AM   #2
OrioN
2008 2500 170" EXT
OrioN's Avatar
Default Re: Is it worth buying a 2010 that just had the DEF system repair?
Yes.
HopTripSploot (02-07-2020)
Old 02-07-2020, 01:09 AM   #3
HopTripSploot
Thank you for your thumbs up! I've never purchased a car by myself let alone a used or a diesel so any reassurance helps!
Old 02-07-2020, 01:33 AM   #4
OrioN
2008 2500 170" EXT
OrioN's Avatar
The first generation DEF systems were prone to failure. Some folks were fortunate to have it repaired under warranty. The replacement and newer parts have proven to be much better and reliable.
Depending on how you drive, the EGR which is a 'consumable' type part, will always need replacement.
Old 02-07-2020, 02:06 AM   #5
ptheland
2013 144" low top Passgr
ptheland's Avatar
Unless the seller can back this statement up with receipts from mechanics specifying the work done, this statement is worthless.
--Peter
The Following User Says Thank You to ptheland For This Useful Post:
Redpillar (02-27-2020)
Old 02-07-2020, 04:36 AM   #6
Kajtek1
I am always skeptic when seller says he put $10k into vehicle and is asking $11k for it.
Good part the pre-DEF dpf are cheap, so are Nox sensors and no SCN coding.
Still have somebody who knows diesels scan it and inspect.
Kajtek1 is offline   Reply With Quote
The Following User Says Thank You to Kajtek1 For This Useful Post:
Bobnoxious (02-07-2020)
Old 02-07-2020, 01:32 PM   #7
HopTripSploot
The seller does have the carfax which shows 28 service records and I'll be asking for the receipt from the mechanic for the supposed work.
We plan on taking a photo of the receipt and calling them ourselves to confirm.
Is there anything else I need to be concerned about on a 2010? Also, has anyone tried cleaning their
EGR every 10k?
I also found a service campaign bulletin for the ECM "Subject: Model 906, Model Years 2010 - 2011
Update Engine Control Module Software." It's not pulling as an actual recall on NHTSA so I'm going to see if his paperwork reflects having this done. If not I'm going to try calling Mercedes with the VIN.
I'm really nervous because I've heard of people buying a 2010 only to have it enter limp mode otw home. This guy is selling it for 14k having just put 10k into it, which also strikes me as suspicious.
Anything I should ask or do (other than have a mechanic look at it) before buying?
Also, would this be a good checklist for a mechanic?
https://drive.google.com/file/d/18qr...w?usp=drivesdk
Old 02-07-2020, 01:47 PM   #8
Kajtek1
Your PPI list is way too short.
This is CPO punch list for cars. Not all might apply, but gives you idea.
To begin the inspection, a mileage/history verification is performed and owner's manuals and spare keys are assembled.
Identifiable Structural Damage (get a magnet for bondo check) *****
Mileage and History verification (CARFAX)
Vehicle Maintenance Schedule Verification (read FSS) *****
Verify all recall and campaigns have been performed
Current Maintenance and Warranty Booklet
Current Owners manual
All spare keys including wheel locks if installed ****
OEM Factory Window verification
Roadside Assistance Program labels
MBCPO inspection label affixed to B-Pillar
Perform testing for Diagnostic codes *****
Engine oil quality and level checks *****
Transmission oil check (bring dipstick for newer cars) *****
Rear Axle Oil check (check for oil residue if you can't open it in the field)
Transfer Case Oil Check
Front Axle Oil check
Antifreeze protection check (green coolant = red flag)
Power Steering Fluid check
Brake Fluid & Clutch Fluid check *****
Windshield Washer Fluid check
Level Control Oil, ADS
Battery Condition and check
Verify functionality of any moving linkages
AdBlue level check
(blowby test) ***** why MB is not checking it? >> put a napkin over oil fill and see if it stays at idling.
Emission control System checks
Fuel Filter check
Spark Plug check
Dynamic compression test (this is hard to do on newer engines, so I do acceleration test instead)
Fuel Injection System
Ignition System check
Pre-Glow system check (is the glow light coming on at start?)
Vacuum pump check (***** for older -pre1998 diesels with weak pumps)
Boost Pressure Check
Air cleaner / Filter check per maintenance schedule
V-Belt and Poly V-Belt check
Engine Mount check
Heating and Ventilation Dust filter per maintenance schedule
Active Charcoal Filter / Pre-Filter per maintenance schedule
Recirculation Air Filter per maintenance schedule
A/C Refrigerant Charge per maintenance schedule
Fuses condition and proper rating
MIL check *****
Instrument Cluster check *****
Exterior rear view mirror check
Exterior mirror fold-back operation
Interior rear view mirror check
Automatic dimming rear view mirror
Radio and speaker function check
Tire Pressure Monitoring System check
CD Changer and DVD rear entertainment system check (if applicable)
Cell phone and BlueTooth check (if applicable)
Cigarette Lighters
Voice Control Systems (if applicable)
mBrace functionality and software check
Switches check
Steering Column adjustment and memory
Seat Adjustment and memory check
Heated / Ventilated Seats
Front Seat Belt Extenders (coupe and Cabriolet)
Front seat backrest latch/ Release (Coupe and Cabriolet)
Front seat backrest latch/ Release Chime / Warning Lamp (Coupe and Cabriolet)
Rear Window Defroster check
Rear Head Restraint Retraction
Rear Window Sunshade
Horn
Headlamp Low / High Beam & All exterior lights
Rear Seat Back rest latch / Warning Lamp
Panorama Roof Function and Rollo Shades
Interior and Entry Lighting
Windshield Wiper / Washer systems
Air-Scarf Functionality
Rain-Sensor Functionality
Drive Shaft Flex discs, couplings and Center Support Bridge *****
Exhaust System /Connections / Supports *****
Parking Brake and Cables
Brake Lines
Tire Wear including spare
Wheel inspection
Wheel bolt torque
Wheel alignment check and adjust if necessary
Brake Rotors and Pads check
Shock Absorbers / Damper struts
Suspension Inspection
Self-Leveling Suspension inspection
Front / Rear Axel Rubber Mounts / Bushings
Check Steering Play *****
Tighten Steering Gear Bolts for 463 vehicle
Front Axle Ball joints
Steering Shock for 463 vehicle
Body Structure Inspection
Glass, Lamp Frames and Lenses
Central Locking System Function
Mechanical Locking at all points
Alarm System Function
Power Window Operations from all points
One touch and convenience Closing
Interior Trim, Inspect Dash, Door Panels, Seat Covers, etc
First Aid Kit - Inspect and Replace if inner seal is broken, check expiration date
Multi-Contour seats
Seat Belt Operation and Condition
Front Seat Belt Height adjustment
Front Seat Center Armrest and hinges
Front Sun Visors / Vanity Mirrors, Rear Vanity Mirrors (if equipped)
Roll Bar / Pop Up Headrest
Parktronic (if available)
Soft top and Seats, condition and operation
Aircap - Check operation and proper movement according to vehicle specs
Door / Trunk Lid Closing Assist
Trunk Release
Tailgate ClosingAssist
Rear Facing Third Seat (Station Wagon)
Door / Trunk / Tailgate Seals, Inspect Drains
Sliding Roof function Drains and Headliner
Inspect Glass Roof for Scratches / Corrective action
Instruments
Instruments
Speedometer / Odometer / Tripmeter (confirm speedometer with GPS)
Steering / Vehicle handling / Centered Steering Wheel ****
Braking System Performance / Parking Brake Operation
Automatic Climate Control Function, Regulation, Display, Odors *****
Cruise Control Function ****
Verify Navigation Function
Verify Distronic Function
Engine Performance
Excessive Exhaust Smoke (Diesel)
Vibration and Noise (Drivetrain / Wheels)
Transmission Shifting (upshift / downshift, Kickdown)
Shift-Lock Operation
Wind Noise
Fluid Leaks - Visible Inspection
All Fluid Levels (under hood)
Engine wash
Trunk Mats
Paint*****
Spare Tire, Tools & Jack, Check Tirefit sealant expiration date
Moisture and Odor
Vacuum and Shampoo
Floor Mats
Carpet
Upholstery
headliner, Door Panels
Buttons Knobs and Vents, Instrument Panel
Glass and Mirrors
Wood and / or Chrome Trim
Vacuum and Shampoo
Screws
Ashtrays
De-grease Door Jambs, Hinges, Kickpanels and Visors
Moisture and Odor
Dings, Dents and Scratches
Examine Paint
Examine and Clean Chrome
Glass and Mirror Housing
Grill
Lamp Lenses
Badges
Trim and Moldings
Wipers
Bumpers
Door Edges, Frames
Wash and Wax
Scuffs and Scratches
Cuts and Gouges
Wash and Polish
The Following 5 Users Say Thank You to Kajtek1 For This Useful Post:
Bobnoxious (02-07-2020), elemental (02-10-2020), GPLYNCHBURG (03-12-2020), HopTripSploot (02-07-2020), JFM (02-07-2020)
Old 02-07-2020, 02:55 PM   #9
Bobnoxious
I would not purchase the vehicle until a diagnostic survey has been performed and analyized. Specifically, ECU and DPF history logs. Logs will indicate if there are stored codes (of past issues) and if the DPF system is functioning properly.
Provided is a sample of a DPF history log (courtesy of esteemed forum member Avanti). Unfortunately, I can't provide an example of a ECU log.
Old 02-07-2020, 03:05 PM   #10
HopTripSploot
I'm taking it to a mechanic to check it out before I buy. Should I ask for this specifically or is this something they will do automatically?
def, egr valve
