SubForums: Events Scanners
Old 08-03-2019, 04:52 AM   #1
joeDiHare
Default Location of second fan: floor or roof?
I installed a fantastic fan on the rear part of the roof.
Since the Sprinter (T1N) doesn't have windows, a second vent (more like a whole with a net) is necessary for wind flow.
Would you recommend a floor or roof vent?
The ceiling seems more common, but think about it, a floor vent
- doesn't have rain-leak issues
- sunlight leaks
- it's pulling in (possibly) cooler air
- it should provide more flow with the other vent being on the ceiling
- and it doesn't take space from, say, solar panels.
I wonder if I am missing some cons?
joeDiHare is offline   Reply With Quote
Old 08-03-2019, 05:09 AM   #2
john61ct
Default Re: Location of second fan: floor or roof?
Need to seal while the engine is running, or at least while driving, depending on location.
And critter screening.
Marine deck plates work well.
Old 08-03-2019, 01:38 PM   #3
Onefin
- sunlight leaks
Floor vent works. Graphite Dave has long been a proponent of them.
https://sprinter-source.com/forum/sh...ad.php?t=38276
Old 08-03-2019, 04:01 PM   #4
GSWatson
2013 144
GSWatson's Avatar
Cheers,
Greg
Old 08-04-2019, 02:01 AM   #5
NMmonkeyman
I have two 2x10 floor vents and no other opening windows. Works very well with roof fan and you can feel the cool air coming in from underneath. Have a typical floor register in place and a small rug to cover them when not in use. I would recommend floor vents as easy way to improve airflow when used with a roof fan.
NMmonkeyman is offline   Reply With Quote
The Following User Says Thank You to NMmonkeyman For This Useful Post:
OrioN (08-04-2019)
Old 08-04-2019, 02:29 AM   #6
john61ct
Just be 100% sure carbon monoxide cannot enter while the engine is running.
Old 08-07-2019, 03:18 PM   #7
brucedog
brucedog's Avatar
We have two roof vents and love them. When we sleep we close all windows, set forward fan to exhaust which pulls cold air quietly right onto our faces through the rear fan. Think about it...is the night air really that much colder ten feet lower? Just my opinion ��
Bruce
2015 170 4x4
2x100w Solar Panels w/ Blue Sky Controller, 224ah AGM aux batteries with Intelli Power 9200 Charger, Dometic 3.8 cu ft AC/DC Reefer, Espar D5 Cabin/Water heater, Thetford Cassette Toilet, Fiamma F65 12.2' Awning, 25 gal fresh water, 3 Panel Bed, Custom Cabinets
brucedog is offline   Reply With Quote
Old 08-07-2019, 03:34 PM   #8
OrioN
2008 2500 170" EXT
OrioN's Avatar
I thought about it......
....not biting, one fan and one floor vent is still better than two roof fans. Why? No need to run the fan motor to get the inside air as cool as the air outside under the van.
Old 08-07-2019, 03:57 PM   #9
elemental
Sounds like both approaches have merits and drawbacks. It is good that we all can make our vans as we want, rather than be forced to a single plan from a single vendor. I myself am planning on two roof vents with fans on a 170" wheelbase van, although I seem to be taking my own sweet time cutting the second.
I've thought about the floor vent/ceiling vent combination as several have recommended it from actual experience. I have decided to stay away from any openings in the floor of the van so as to keep the elements at bay while driving in inclement weather, especially with winter roads treated against icing. Potential carbon monoxide intake to the living space should the exhaust spring a leak also was a risk I thought to avoid, although it would only be a problem if the engine were running. I have managed enough roof real estate on a 170" wheelbase van to have two fans, one forward, one aft, with 4 solar panels in between; this also provides simultaneous intake and exhaust so as to achieve a gentle flow through. On a 144" wheelbase the roof real estate would be more precious, and the floor vent's benefits would take on more allure for me, I think.
elemental is online now   Reply With Quote
Old 08-07-2019, 04:07 PM   #10
OrioN
2008 2500 170" EXT
OrioN's Avatar
Close the vent while driving.
fan, floor, vent
