Old 07-07-2019, 11:16 PM   #1
Gsand31415
Default P22A1 code, CEL light, lost power on upgrade
I bought my 6 cyl 2011 used with 114k miles with a CEL light lit and a NOx sensor code and naively assumed it would be a cheap fix (I previously drove Fords and for the most part did my own minor repairs and maintenance). After belated research, I had it professionally replaced and drove the next 6,000 miles without a problem.
Recently the CEL lit again with a P22A1 code and today while driving up a mountain pass suffered a dramatic loss of power. Wife was driving and I didn't have a full view of the dash but from my angle didn't see any additional lights or messages. Crawled off the freeway and hooked up the ScanGuageII and couldn't remember how to view codes, but did get a prompt to clear them, and not really thinking things through under pressure I hit "clear". The CEL light went out and it ran normally for the couple hundred miles to get us home.
My questions:
1. Were we in "Limp Home Mode? Is there a dash indicator or is that a diagnosis by symptom?
2. If it was in LHM, would a restart have been sufficient, or was the clearing of the code necessary?
3. Should I replace both NOx sensors with the latest generation (gen5, if I remember the posts)? I seem to remember that both need to be on the same generation.
4. I'm sure I can do the mechanical part of the replacement myself. Is there also programming needed that can only be done at the dealer/shop?
5. If it is a DIY job, where is a good place to buy the new sensors?
I feel like a dope for clearing without viewing the code(s).
p.s. Since I can't create new tags, where do I find the list of existing tags
Gsand31415 is offline   Reply With Quote
Old 07-07-2019, 11:24 PM   #2
Default Re: P22A1 code, CEL light, lost power on upgrade
"Dramatic loss of power" could simply be the turbo system dropping off-line.
With the ScanGauge you can look at MAP (manifold absolute pressure) while you're driving to see if it's properly boosting to 30 psi (more or less).
(that's a 15 pound boost, so if you're already at altitude (mtn pass), it may be a few pounds lower (say: 26 or 27).
Many things can cause a turbo drop-out, and a "turn off engine, count to 5, turn on engine" can clear the symptom.
If it's a small leak (such as a *slightly* split hose, or *slightly* loose clamp) you can drive for months without noticing it, *until* you put a heavy load on the engine ... when the ECU notices the leak, it stops even trying to use the turbo until you turn off the engine.
One of the features of the scangauge is that it's small enough to leave*permanently connected* so that you can monitor engine systems along the way.
--dick (i don't have an NCV3 code book, so i can't translate P22A1 to useful text)
Added: a little googling strongly hints that it's the "downstream NOx sensor"
This thread, for example: https://www.dieselplace.com/forum/63...ns-system.html
hints that the Check Engine light will return. Actual readout of the NOx sensors would be informative. (an Autel scanner may be able to do that ... i don't have an NCV3, so i can't speak from experience)
Old 07-08-2019, 01:52 AM   #3
The Grand Tour
Banned
Define the second "it" in that statement- what was it that you had professionally replaced, and why?
You should not replace anything until the Cause of your Concern has been accurately diagnosed. To do anything else would be what we commonly refer to within the vehicle repair profession as "guessing", and guessing is by far the most expensive and time consuming method to repair a vehicle.
Old 07-08-2019, 03:59 AM   #4
Gsand31415
The well-respected shop did extensive troubleshooting with their Star system, and after swapping the two sensors and finding the error code move to the other sensor, they replaced the failed NOx sensor. It took three days and there was 150 more miles on the odometer, so I'm pretty sure they put some time and effort into their diagnosis and road testing.
In reading this forum I have come under the impression that the earlier generations of sensors are good for sh*t. My local Mercedes shop (the previous service was 3000 miles away, not here) seems to have a reputation for spotty but expensive service, and if I'm making the choice between spending $500 on their diagnostics vs. the same on more reliable sensors, I'll take the chance on my own guess. I've only used them for a recalled airbag issue, but they let me down a little on that interaction. Not a big deal, but if I was asked to give a review, it would have been a little below expectations.
I spent my career working with equipment that would give cryptic error codes when thing went wrong, and developed a talent for cost-effective troubleshooting. I know that my code(s) may actually have been caused by problems in the DEF system or elsewhere, and that's why I went with a pro the first time around.
On one of my Fords, The TFI ignition modules had a reputation as bad as the earlier Mercedes NOx sensors, and I replaced a couple of them. I also had problems with the generally reliable MAF sensors which I traced to a bad connector without replacing the sensor. I'm certainly not a pro in this field, but I do like to understand a problem before I act, so that's why I am asking these questions. I can't help noticing that you didn't answer a single one of my questions.
I suspect that others on this forum could cite many examples of being charged for the replacement of perfectly good parts at Mercedes dealers. I've read a few of these accounts. I think you have to grant me that replacement of the NOx sensors would at least be a somewhat educated guess.
Old 07-08-2019, 04:38 AM   #5
The Grand Tour
Banned
Time and effort mean nothing without skill. I'm glad it worked out okay for you.
Good.
On one of my Fords, The TFI ignition modules had a reputation as bad...
I never really concerned myself with the reputation of Ford Thick Film Ignition modules, but I have diagnosed and replaced many of them- it was a common failure point.
Good.
Sure I did- I answered question #3.
I'd be interested to see those examples, if you're able to show me.
Guessing is guessing...
Old 07-08-2019, 12:23 PM   #6
Mike DZ
2016 View 24V (2015 3500)
"1. Were we in "Limp Home Mode? Is there a dash indicator or is that a diagnosis by symptom?"
The term "LHM" is being used by our various forum members to describe a number of different protective behaviors that programming in the ECU commands. It may be engine or transmission related.
"2. If it was in LHM, would a restart have been sufficient, or was the clearing of the code necessary?"
Some LHM will be cleared by recycling the power, as autostaretx indicates. Other "limps" require specific corrective action to clear.
As autostaretx implies, loss of boost system integrity fits the situation and symptoms you note (uphill, high demand). Inspection of boost hoses and seals would be the next step in diagnosis in that area. A small split in our boost hoses can be very hard to find, look for oil spray in the area (a small amount of oil in the boost hoses is normal) and feel the hose for irregularities.
I don't know enough about the NOx sensor system to make a suggestion about replacement. I am not sure how a NOx sensor failure would cause the symptoms you describe.
2016 View 24V (2015 3500) towing a 2016 Sonic Hatchback
Mike DZ is offline   Reply With Quote
The Following User Says Thank You to Mike DZ For This Useful Post:
Gsand31415 (07-08-2019)
Old 07-08-2019, 04:03 PM   #7
irvingj
2015 RT SS Agile (3.0L)
As far as question #3, yes, version 5 seems to be the "current" version of the NOx sensors.
If it can be determined which version you have... and if they're NOT v.5, It might be a reasonable idea to upgrade them, regardless of "throwing parts at the problem" inefficiencies. Hey- they did that with mine; earlier versions apparently just didn't seem to hold up very well. Not sure if they need to be the same generation, but if they're old enough, as I understand it, there can be a compatibility issue.
If you can get at yours, here's a pic of the numbers on mine, a 2015, which came with version 2 sensors (the "Q02" on the part number; the new one has "Q05" on it).
Pics were sent to me by the tech that replaced them, so I don't know if they have to be removed to see the numbers or not. No prevarication on his part -- he just replaced both of them.
Hope this helps!
2015 RT SS Agile, 3.0 V-6
The Following User Says Thank You to irvingj For This Useful Post:
Old 07-09-2019, 09:51 PM   #8
Gsand31415
Inspection of the turbo output did not reveal any obvious leaks. The rubber hose going down to the cooler is coated with a thin film of oil and the one going back up is dry. I don't understand the connectors on these hoses -- they all seem to be held in place by a spring-wire mechanism I haven't seen before, and they all have some play -- not a solid-feeling connection but I have a feeling that might be normal since they all jiggle the same amount.
Rather than MAP, I set the ScanGauge to Boost. It ramps up to about 10-12 psi on a normal acceleration, 20-22 PSI when going up a steep hill at about 40 mph. I won't have time to take it to a mountain pass for a couple of days where I can try it out at highway speeds and full load. I could take it up Mt. Baker but you can just go so fast between the switchbacks.
It's still driving fine with no CEL, but with a P229F code in memory.
Old 07-10-2019, 12:30 AM   #9
Mike DZ
It has been noted on the forums that some of the pressure hoses are porous which may explain the thin film of oil. There are O rings inside the joint that seal the pressure hoses. I normally run boost on my scan gauge and my max boost is 22.x. So, if you are holding 20ish psi of boost for an extended period you don't have a problem with boost system integrity.
If you do end up replacing one of your NOx sensors, I believe it has to be "taught in" at a MB dealer or independent with an appropriate diagnostic tool (Xentry or similar).
Gsand31415 (07-10-2019)
Old 07-10-2019, 10:39 PM   #10
Gsand31415
I hate to ask because my lovely wife was driving, but is it possible to trigger a boost shutdown by your driving habits? At the time it shut off, we were on a long upgrade in heavy traffic and she was trying to maintain 70+ mph. I suspect the pedal was mashed to the floor much of the time alternating with very brief instances of no throttle pressure at all.
lhm
