Old 03-26-2019, 02:56 PM   #1
tsudapod
Default Jumping aux battery. I AM AN IDIOT
Whats up yall
2017 MB 144 4x4 outfitted by tourig in golden CO. Dead battery for whatever reason and like an idiot I tried (unsuccessfully) to jump the aux battery. Now the cabin lights and outlets that run off the aux when motor is not running do not work. I went to MB and they replaced the aux battery (300 bones$$$) still nothing works. No clue what to try next. Open to any suggestions. Yes I already know Im an idiot .....
Greg
tsudapod is offline   Reply With Quote
Old 03-26-2019, 03:35 PM   #2
Oilburner
2004 2500 140"cargo l/r
Oilburner's Avatar
Default Re: Jumping aux battery. I AM AN IDIOT
First I would check all fuses.
Oilburner is offline   Reply With Quote
The Following User Says Thank You to Oilburner For This Useful Post:
tsudapod (03-26-2019)
Old 03-26-2019, 03:49 PM   #3
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Which battery was dead, the one under the hood or the one under the drivers floor?
And are you still in Golden? If so call Dennis at Linden Engineering, he'll sort you out. And for a lot less than the stealership!!!
Keith.
36,000 miles from New
Old 03-26-2019, 03:53 PM   #4
Bobnoxious
2017, not under warranty?
Old 03-26-2019, 03:55 PM   #5
Ziggy
After fuses, check for power at the socket, then try new light bulbs.
Ziggy is offline   Reply With Quote
Old 03-26-2019, 05:30 PM   #6
tsudapod
Keith.
The starter battery under the seat was dead but I was too stupid to know that there were two batteries and I tried to jump the aux when
Old 03-26-2019, 05:55 PM   #7
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Surely a 2017 has its starter battery under the floor and NOT under the seat!
Old 03-26-2019, 09:00 PM   #8
john61ct
Jump the aux?
Meaning what exactly, applied jumper cables to the aux battery from an outside vehicle? While trying to crank the propulsion engine starter?
Old 03-26-2019, 09:25 PM   #9
Bobnoxious
Default Re: Mercedes Benz Sprinter 906 NCV3 jumpstart locations.
...For future reference, utilize the jump starting feature located in the engine compartment. Refer to "Jump Starting" in Owner's Manual for more information.
life_goes_on (03-27-2019)
Old 03-27-2019, 01:30 AM   #10
Montucky
I'd also check the relay off the aux battery - as I understand it, the relay closes (passes current between aux and starter battery) when the ignition is turned on, so between your connected jumpers and a more fresh aux battery, you might have pushed too much current through the relay. If so, it's a pretty simple fix.
And don't beat yourself up - it's an easy mistake to make!
Montucky is offline   Reply With Quote
The Following User Says Thank You to Montucky For This Useful Post:
dynaco1 (03-28-2019)
aux battery, jump start
