Old 10-08-2017, 10:11 PM   #11
JFloFoto
Default Re: L Track Bed Idea
Originally Posted by caseylentz View Post
This looks like the outside van bed frame ? What did you use for the horizontal piece that fits into the L-track ? In your application it looks like there is no center mount to help support the bed. Is that the case ?
It's a modified RB Components platform bed. I modified their package so I could sleep crossways. The horizontal bar is by RB as well. I machined a center support which hooks into my existing L-track for added support. See photo.
Sent from my Pixel using Tapatalk
The Following User Says Thank You to JFloFoto For This Useful Post:
sketchbook (02-01-2019)
Old 10-08-2017, 11:07 PM   #12
Eka
Eka's Avatar
You could use removable cross bars at each end that takes up the tension load from side to side. A vertical beam of some sort can be floor mounted, with a cross bar at the ceiling to keep the tops spread apart. It then has the L-track mounted to it, and takes up the load instead of the wall. Ratchet straps can exert a very strong pull. I was also going to mention trampolines on catamarans, but they have been mentioned already.
Eka is offline   Reply With Quote
The Following User Says Thank You to Eka For This Useful Post:
Aqua Puttana (10-09-2017)
Old 10-09-2017, 01:19 AM   #13
Originally Posted by Eka View Post
You could use removable cross bars at each end that takes up the tension load from side to side...
My thinking was along similar lines. Then I remembered that a mattress was mentioned. If a mattress is in the mix, and cross bars are included, why not just add a few more cross bars and a light slat bridging?
IF a tramp/net is really desired then using stretcher bars could work. My vision would be stretcher bars along the wall side to minimize the number of L-track attachment points necessary. The (slightly heavier duty) end stretcher bars could be hinged/locked to allow easier stowage.
The above said, I have slept on Corsair and other multi-hull tramps/nets. They can be very comfortable when they are the stiffer materials used for most racing designs. With stretcher bars and proper material a mattress may not be needed.
P.S. - I agree that ratchet straps stretched across the walls may be able to deform the walls. I know that a stretcher bar frame tramp will not be a problem. That design will minimize the inward stress on the walls.
Old 10-09-2017, 02:33 AM   #14
caseylentz
caseylentz's Avatar
Exclamation Re: L Track Bed Idea
What are stretcher bars ? I've been googling but not seeing them. Can you point me in the right direction and provide a link ?
Cheers
Casey
caseylentz is offline   Reply With Quote
Old 10-09-2017, 01:24 PM   #15
What are stretcher bars ? ...
Stretcher bars are individual pieces. A continuous support is generally referred to as a frame.
Stretcher bars provide a support along the sides of the net/tramp/tarp. The stretcher bar is attached to the fabric. That allows fewer attachments to properly support/hang the bed or tarp.
Pipe berths use a form of stretcher bars.
Post #13 mentions stretcher bars.
http://forums.sailinganarchy.com/ind...g-pipe-berths/
A link that mentions caravans.
http://www.ybw.com/forums/showthread.php?17853-Pipe-Cot
Old 10-09-2017, 02:38 PM   #16
Dakine1
Originally Posted by JFloFoto View Post
Not a cargo net bed setup, but used vertical l-track.
JFloFoto: This seems like something I have been looking to do. I wanted to have my bed adjustable for different applications. I wonder if I could do something like this but somehow spring the bed weight somehow and raise it during the day for use and storage below. Thanks for the ideas!
Dakine1 is offline   Reply With Quote
Old 10-09-2017, 05:33 PM   #17
Beer30
Has anyone used the holes in the interior with round conduit set in them for a simple bed support?
Beer30 is offline   Reply With Quote
Old 01-10-2018, 06:54 PM   #18
photuris
Default
I have been considering doing something similar as a sleeping solution for my two boys (8 and 10 years old, neither weighs more than 70lbs).
Can I put an l-track on each wall and then using a ring type attachment hook up a carabiner and hang up two hammocks for them?
photuris is offline   Reply With Quote
Old 04-07-2018, 02:33 PM   #19
ScottJD
Ever get an answer? Iím thinking of doing the same thing
ScottJD is offline   Reply With Quote
bed, conversion, passenger
