Old 06-02-2017, 01:30 PM   #11
smiller
2008 View J (NCV3 3500)
Default Re: ID Parts has DPFs and other things
Originally Posted by David Brown View Post
A new DPF must be introduced to the computer? Other than a dealer, what scanner is able to do this on a 2013 model?
Yes, I believe so, base ash level should be reset at least. I have seen reports of people simply replacing the DPF and doing nothing else but that's probably not completely kosher, or at the least if you're still throwing codes then it's something to look into. I haven't had to perform the procedure myself yet so I'm not an expert, maybe one of the pros on the forum can comment. As to an appropriate scan tool, beyond the high-dollar items I would guess that the Chinese STAR clones could do it, C3 or maybe a C4 would be required on a 2013. There are several threads describing these tools and they seem to have a lot of capability for the price (around $500 depending on what hardware you buy.)
smiller is online now   Reply With Quote
David Brown (06-02-2017)
Old 06-02-2017, 06:07 PM   #12
cevans
cevans's Avatar
David - thanks for the shout out and kind words.
I've got an inquiry out to a few OBD tool makers that I've worked with in the past about ash load reset.
Corey@IDParts (dot) com - Fighting against leaking oil cooler seals!
Manager of Mercedes & Sprinter Parts @ IDParts.com - 888-444-7951
Sprinter Maintenance Service Kits / Sprinter Brake Sets / Sprinter NCV3 Oil Cooler Seal Kits
cevans is offline   Reply With Quote
Old 06-02-2017, 06:54 PM   #13
Bobnoxious
My only experience is with Xentry simulation mode. There is a DPF "Teach-in" process I assume resets the Ash load calculation.
Old 06-02-2017, 09:40 PM   #14
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
How about the new Autel MD808?
Here is its list of applicability...
http://download908bak.auteltech.net:...20FUNCLIST.pdf
Note the link on the AutelTech website is incorrect...
http://pro.auteltech.com/measurecar-1-1.html?m=4
Keith.
36,000 miles from New
The Following 2 Users Say Thank You to Cheyenne For This Useful Post:
Bobnoxious (06-02-2017), smiller (06-02-2017)
Old 06-02-2017, 09:58 PM   #15
smiller
Looks very interesting, appears to support all of the most common service requirements (DPF re-learn, steering wheel center setting, injector replacement, etc.), and for all of $249!
Would love to hear from someone/anyone who has used any of these functions on a Sprinter.
https://www.amazon.com/Autel-MaxiDia.../dp/B07194V73G
Old 06-03-2017, 10:16 AM   #16
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
smiller,
The Autel you have linked to on Amazon is, i believe, the 'standard' MD808, or '4 system' model.
I think you need the 'PRO' version to get the full DPF, SCR capability...
https://www.amazon.com/Autel-MaxiDia...5VRQYCDP3MCTPX
Keith.
Edit: Quote from amazon questions "MD808 can only access to Engine, Transmission, ABS, and Airbag (SRS) systems while MD808 pro support Read/Clear Codes and Live Data functions for ALL systems".
Old 06-03-2017, 01:40 PM   #17
smiller
Ah, thanks. I thought Autel had done away with their 'standard' and 'pro' designations but maybe not. In any event the pro model is still under $300 so not much pricing difference and still a great deal if it really does support all those bidirectional functions on a Sprinter.
Old 06-29-2017, 03:34 PM   #18
deanoshiro
2004 Dodge Sprinter 2500
deanoshiro's Avatar
Paid $225 today for MD808Pro with 3rd day air
"You're only known for the worst thing you do." Dean Oshiro 1978
deanoshiro is offline   Reply With Quote
dpf, egr valve
