Old 01-24-2017, 02:39 AM   #1
pworthington
Lightbulb Sprinter Electrician near Seattle
Hello All,
I'm looking for a good Sprinter electrician near Seattle. My electrical system is 90% there, but I want to improve the connection from my house batteries/ solenoid to the van for charging (while driving). Either an outfitter/upfitter, marine/RV electrician, or savvy person...I'm happy to connect and compensate for services!
Please let me know
Thanks in advance
pworthington is offline   Reply With Quote
Old 01-24-2017, 05:18 AM   #2
Sprinterbuild
Default Re: Sprinter Electrician near Seattle
Are you trying to charge off of the auxillary battery charger or a separate system? I would recommend putting in a positive disconnect switch just to keep things isolated. Even using the d+ circuit I was getting a pretty heavy 35 amp draw off my house batteries right after starting. New starting battery helped reduce that but I would still play it safe
2006 Dodge sprinter Cargo I5
Sprinterbuild is offline   Reply With Quote
Old 01-24-2017, 02:04 PM   #3
pworthington
I'm trying to charge my house batteries (two 6V AGMs) off my vehicle while driving. I know there are many ways to achieve this. You can tie directly to the alternator or take the excess power from starter battery.
House Batteries -> Solenoid -> Starter Battery/ or Alternator
I've seen a lot of wiring diagrams for Aux systems, but nothing that shows the actual connections to the vehicle.
I want to charge my Aux batteries while driving, but only if my starter battery is at 100%, and the draw stops once the Aux batteries are at 100%.
I may be overthinking this, but I want to make sure it's done correctly.
Old 01-24-2017, 05:57 PM   #4
What year is your Sprinter?
IF it's a T1N, and you don't have a roof-top AC, there's an unused spot on the Power Distribution Block that's hanging on the starter battery's positive post.
That's a handy spot to attach the Aux Bat feed (via a fuse in the block).
pworthington (01-25-2017)
Old 01-25-2017, 02:06 AM   #5
pworthington
That looks like a handy spot to tap into. My van is a 2016. Interestingly, the outfitter who originally hooked up the system plugged into fuse position #7 under my seat (which is also visible when removing the oustside cover). Funny thing...he never put a fuse in its slot. That can't be good!
Old 01-25-2017, 02:14 AM   #6
Lotus54
I just fitted am isolator to my Eurovan- ran a cable to the house battery from it.
Not a big deal.
Charges the house battery when the engine is running, will not discharge the vehicle battery. This one has a button that will Allow the house batter to assist for starting If the vehicle battery is low.
2006 Airstream Interstate (T1N)
2014 OSSA Explorer AND Factory R 300
2016 Beta 300 Factory 4T + Beta X-Trainer
Lotus54 is offline   Reply With Quote
Old 01-25-2017, 04:17 AM   #7
Here is a photo from another thread of the positive mess on an NCV3 battery (plus some words and arrows)
If i were doing it, i would use a RED wire (the "universal" color for positive)
The silver box with the ?? on it is a pyro disconnect ... in the event of a crash that heavy black cable is automatically disconnected from the battery.
outbound (01-25-2017), pworthington (01-25-2017)
Old 01-25-2017, 05:59 AM   #8
HarryN
In case you forgot, you asked the exact same question in a thread that you started in June. - Looking for a van up fitter.
https://sprinter-source.com/forum/sh...ad.php?t=47837
I realize that you and the low - price up fitter that you hired didn't work out, but are you really going to seek out another lowest price bid again? It seems like after the postings that you made about the other person you hired to do work, the last thing that you would want is to go anywhere but a premium shop or a MB dealer.
There is something very unsettling about your approach to business and hiring people to work on your van.
Old 01-25-2017, 01:53 PM   #9
pworthington
HarryN
You're right...I've been looking for someone in my area to help with electrical (which has already been installed, but not 100% correct). I do absolutely want to work with the best in my area on this. Learned my lesson the hard way, now I'm trying to surround myself with the best possible tech/ installer to help sort this. Not trying to cheap out, at all!
The Following User Says Thank You to pworthington For This Useful Post:
Old 01-25-2017, 01:56 PM   #10
pworthington
Autostaretx
Thank you for the photo/ diagram! This is very helpful. Is there a specific spot the (+) should go onto the starter battery terminals? I see a few places it could attach.
Also, what is all this talk of the D+ terminal under the driver's seat? This sounds like a good way to charge the house batteries without connecting to the starter battery? Correct me if I'm wrong!
Thank you again!
alternator, aux battery, electrician
