Old 02-03-2014, 09:29 PM   #1
driveon
Default Aux Battery under hood
Can either of the following batteries by installed under the hood of a 2011 NCV 3 Sprinter van?
Lifeline GPL-31XT 12 volt AGM 125AH battery
12.90 x 6.75 x 9.27 (L X W x H) 74 lbs
http://www.lifelinebatteries.com/rvflyer.php?id=30
OR
Lifeline GPL-30HT 12 volt AGM 150AH battery
13.46 x 6.77 x 11.95 ( L x W x H) 96 lbs
http://www.lifelinebatteries.com/rvflyer.php?id=4
Any idea what the factory stock under hood AUX battery tray maximum weight limit is?
What is the largest group battery size and Amp hour capacity which can be mounted under the hood ?
What is the largest group battery size which can fit under the passenger seat?
driveon is offline   Reply With Quote
Old 02-03-2014, 09:34 PM   #2
4wheels
Default Re: Aux Battery under hood
I`ve got 230AMP bank under the hood . I had a factory 100amp battery but upgraded to two golf cart 6v batteries . Had to fabricate the bracket and the tray .
My
4wheels is offline   Reply With Quote
Old 02-03-2014, 09:35 PM   #3
driveon
Which 6 volt brand and model are the batteries you installed?
What is the individual weight of each battery?
thanks
Old 02-03-2014, 09:40 PM   #4
glas1700
glas1700's Avatar
The tray is designed for a Group 49 battery that's ~7.5 inches tall (192mm) and weighs 50-55 lbs, so I doubt that anything much taller will fit.
Byron
07 Itasca Navion
06 Sprinter 3500 Cutaway
97 Geo Tracker 4WD toad
Old 02-03-2014, 10:21 PM   #5
4wheels
I remember now , I had to move the ECU , too. See my post - golf cart batteries under hood
Two years - no issues . I love it . Now , i bought a pure sine wave inverter and 4 Trojan T-105 RE batteries . Will mount them underneath .
Old 02-03-2014, 10:25 PM   #6
4wheels
thanks
Just regular 6v golf cart batteries . I think each weighs about 60lb .
Old 02-03-2014, 11:02 PM   #7
owner
owner's Avatar
AGMs wont like the heat under there anyway.
Old 02-04-2014, 12:03 AM   #8
GeorgeRa
2013 Sprinter DIY 144WB
GeorgeRa's Avatar
This battery fits into factory auxiliary battery tray straight up or sideways - http://www.fullriverdcbattery.com/battery/DC115-12
George.
dprice667 (09-06-2017)
Old 02-05-2014, 03:57 PM   #9
jdcaples
Not Suitable w/220v Gen
jdcaples's Avatar
OR
What problem are you trying to solve?
-Jon
Old Crows (02-06-2014)
Old 02-06-2014, 02:33 AM   #10
driveon
I am seeking solutions and options to both scenarios I addressed.
I am trying to arrive at the maximum amp hour battery versus physical size limitations I can fit under the hood or under the passenger seat before having to consider multiple 6 volt batteries mounted inside the van.
The Following 2 Users Say Thank You to driveon For This Useful Post:
jdcaples (02-06-2014), Old Crows (02-06-2014)
aux battery, gpl-30ht, gpl-31xt, lifeline batteries, under hood battery
