Old 12-30-2017, 04:16 PM   #1
pinzgauer
Default 200A alternator bolt up if replacing 150A?
Looking to replace the 150A alt on our 06 T1N passenger.
Given it's part time use as a simple camper, I'd like to upgrade to the AL0817N alternator.
Pics look like it's a bolt up proposition, and car places say it will fit.
But none of the write ups specifically mention replacing a 120/150 with a 200A.
I've ordered it, as I knew if I did not I'd regret not spending the extra $120 to get the extra capacity down the road.
It's been occasionally throwing belts, and had a diesel leak in the small hose near the front of the block (top one of the two 90 degree hoses) that made things messy. (now corrected with proper swedish EFI clamps, etc, and factory hoses)
Now no charging, so I'm guessing either the belt jumps were early warning on the clutch failing on the alternator or fuel on the belt/pulleys caused a problem.
Any input welcome! I've ordered the 200A, so will try it unless someone knows it will work.
pinzgauer is offline   Reply With Quote
Old 12-30-2017, 09:28 PM   #2
Default Re: 200A alternator bolt up if replacing 150A?
It's bolt on. I replaced my 90 with the 200a, 50k miles and counting.
Old 12-30-2017, 11:07 PM   #3
lindenengineering
OR of course it might simply need a new tensioner and pulleys plus an accessory belt..
Change out the lot at 100,000 miles max/tops.
Dennis
The Following User Says Thank You to lindenengineering For This Useful Post:
kjg912 (01-28-2018)
Old 12-31-2017, 01:55 AM   #4
pinzgauer
Dennis
Fresh belt as well as idlers and tensioner a bit back.
I do think I'm going to recheck the routing to make sure the last shop did not miss the alternator!!!
Old 12-31-2017, 08:43 PM   #5
Nautamaran
2004 140 SHC U.S. T1N
Nautamaran's Avatar
Dennis
Mine look original at 170,000... belt is okay but I guess my spring list just got a bit longer?
Nautamaran is online now   Reply With Quote
Old 01-28-2018, 04:00 PM   #6
pinzgauer
Bolted right up. Saved my 150A in case its just brushes.
Thanks all for the quick confirmation
Tags
2006, alternator, passenger, t1n
