SubForums: Events Scanners
Old 12-28-2012, 09:00 PM   #1
ukcarrecovery.com
ukcarrecovery.com
Default Help needed! Mercedes Sprinter 311CDI Sprintshift hydraulic/gearbox oil change
Hi, I've got 2005 Mercedes Sprinter 311 CDI sprintshift model, I'm having problem with hydraulic pump and going to remove it by myself, I just wana know that is there only one oil for gearbox and hydraulic pump or separate oil for gearbox and separate oil for hydraulic pump, could some one please tell me how to change hydraulic pump/gearbox oil? also do I need to bleed it after refitting the hydraulic pump and what's the procedure to bleed it?
Help would be much appreciated.
Thanks
ukcarrecovery.com is offline   Reply With Quote
Old 12-29-2012, 06:51 PM   #2
mean_in_green
>1,800,000m in MB vans
mean_in_green's Avatar
Default Re: Help needed! Mercedes Sprinter 311CDI Sprintshift hydraulic/gearbox oil change
It's been covered before - search using the drop down box in the blue bar above. The transmission and hydraulics have separate fluids.
mean_in_green is offline   Reply With Quote
Tags
hydraulic pump, hydraulic pump oil change, sprinter 2005, sprintshift
