MobileCC
I want to show you guys how easy it is to change the rear axle ratio on a sprinter van without the need to scn code. 2 modules need to change varriant code ezs906 nafta and egs 53 This will work with vediamo or xentry developer version
In the following pictures I connected to the EGS53 transmission module ..according to my vin SEAL is AR3 (4,111) and SEAK is AR2 (3,923) when you connect with your van your code will be different for example i posted a pic of a coding sheet it may be SA8R which is 4,111 gear ratio and if you want the 3,727 gear ratio you would choose SA8S If transmission goes to
limp mode just simply choose a different code up or down on the the list in till you find the right one .. it really is that easy Your transmission code will not be the same as mine its based off you vin just choose one up or one down code ..
