Replaced serpentine belt, idlers, tensioner, thermostat, induction hoses, rad hoses, coolant Zerex G5, split the cooling stack and sent all the expired bugs to a better place, oil and filter, started changing the brake fluid by vacuum bleeding. This was all age related (van, not me) preventative stuff, as the vehicle only has around 80,000 miles. I used the radiator swing-out technique, and would do so again. Everything that came off appeared to be in very good condition, with the exception of grooving on the smooth small idler, anti-freeze and brake fluid were clean. I replaced the small idler with the larger grooved style, which means I'm short one plastic idler dust cover. I haven't looked very hard, but does anyone know of a source for them?
