Old 11-05-2019, 05:05 AM   #971
hein
Van Guru
Default Re: 2010 3500 RV build (formerly painted seat pedestals)
Originally Posted by Rtarannum View Post
Hi Hein,
Do you have a blog of how you did this? I am very new and would like to attempt doing this myself and could use your help. I will appreciate any further info.
I would be honored to explain all the details and answer your questions in a phone call. Please call at your convenience.
All the best,
Hein
DIYvan
541 490 5098
2010 MB 3500 RV conversion.
Old 12-03-2019, 07:33 PM   #972
hein
Van Guru
We have used a Scangauge in our Sprinter for as long as we've had the van and consider it an essential accessory. We had an early version that could not read all the engine parameters so I sent it back for an upgrade and Linear Logic offered to pre-program the gauge with the following:
*Description* *TXD* *RXF* *RXD* *MTH* *NAME* *Notes*
Boost Air Temperature (F) 07E02220A6 C32100000000 3010 00090032FE35
BAT 4.22+
DPF Delta Pressure (PSI) 07E02220C4 C32680000000 2810 001D00C80000
DPS 4.22+
Exhaust Back Pressure (PSI) 07E02220C4 C562862037C4 4010
001D00C80000 EBP 4.22+
Upstream DPF Temperature (F) 07E02220C4 C562062037C4 4808
048000190000 DPT 4.22+
Fuel Tank Level (Gallons) 07E02220EE C32580000000 1808 014A007D0000
GAL 4.22+
Oil Temperature (F) 07E02220EE C32300000000 3010 00090032FE35 EOT
4.22+
Rail Pressure (PSI) 07E02220EE C32340000000 4010 001D00C80000 RPS
4.22+
DPF Ash Mass (Grams) 07E0222094 C32300000000 4808 004000190000 DPF
4.22+
Upstream Turbocharger Temperature (F) 07E0222083 C56206203783 4808
048000190000 UPT 4.22+
Actual Gear (#) 07E12190 C56106902000 4808 000100010000 GER 4.22+
Converter Slip Speed (RPM) 07E12190 C32200000000 3010 000100010000
SLP 4.22+
Transmission Fluid Temperature (F) 07E12190 C32200000000 1808
00090005FFC6 TFT 4.22+
I got the gauge back recently and remounted it on top of the steering column using 3M VHB and an angle bracket that I had heat formed out of 1/16" thick ABS plastic.
First photo below. Gauge with bracket and VHB attached.
Next. Flaming the plastic so VHB would stick better.
Gauge cable routing into space where tilt-wheel lever come out.
Last photo. Final installation as viewed by driver.
Next up will be to get on the road and watch all the newly accessible parameters. I typically watch LOD, coolant temp, battery voltage and boost pressure. Looking forward to seeing if the engine is in regen mode. Which parameter would be best for determining that?
All the best,
Hein
DIYvan
541 490 5098
The Following 3 Users Say Thank You to hein For This Useful Post:
GeorgeRa (12-04-2019), HighPockets (12-03-2019), SD26 (12-04-2019)
Old 12-04-2019, 01:54 PM   #973
SD26
2012 NCV3 3500
Thanks for the X-Guage codes. I have mine updated to 4.22 with quite a few of the ones you have listed, but not the DPF ash in grams...
SD26
2012 Sprinter 3500 170EXT
2004 Sprinter 2500 158, totaled by deer 5-2019
SD26 is offline   Reply With Quote
Old 03-10-2020, 09:16 PM   #974
hein
Van Guru
Ever since I upgraded the Scanguage with new X-guage codes I have keen to watch for evidence of a regen in process. Last night, Kim and I took the van for a spin and the Diesel Particulate Temp was showing 1650F. Bingo! Let's keep driving... After a few more miles (~15) of interstate driving the temp was back down to more normal 1150F. Regen complete.
Thanks Scanguage!
All the best,
Hein
DIYvan
541 490 5098
Old 03-11-2020, 12:18 AM   #975
GSWatson
2013 144
GSWatson's Avatar
Hein, Is that on your 2010 Sprinter? I cant get the codes to work on my 2013, and I thought I had heard that pre-2014 engines didnt respond to certain codes.
Cheers,
Greg
Old 03-11-2020, 04:35 AM   #976
hein
Van Guru
Originally Posted by GSWatson View Post
Hein, Is that on your 2010 Sprinter? I can’t get the codes to work on my 2013, and I thought I had heard that pre-2014 engines didn’t respond to certain codes.
Cheers,
Greg
Yes, its on our 2010. I sent my older Scanguage in for an update and they did the programming for me. I have been monitoring Upstream DPF Temperature (F).
All the best,
Hein
DIYvan
541 490 5098
