Old 09-11-2019, 12:42 PM   #1
lukeyt123
Default Intermittent Heater blower / wipers
Heater blower had been intermittent sometimes working fine on all settings and sometimes not at all. Realised the other day that when the heater blower wasn’t working my wipers on the intermittent setting weren’t working and sure enough started working again when the blowers came back to life. But the next time blowers stopped working the wipers carried on fine. Any ideas?
lukeyt123 is offline   Reply With Quote
Old 09-11-2019, 02:49 PM   #2
Aqua Puttana
Poly - Thread Finder
Aqua Puttana's Avatar
Default Re: Intermittent Heater blower / wipers
Coincidental?
I'd use the schematics to see if there is any common feed/ground points though.
Old 09-11-2019, 04:20 PM   #3
hepcat
Just an old guy...
hepcat's Avatar
An intermittent heater blower is sometimes an indication that it's about to seize, especially if it works for a while after hitting a jarring bump, and then stops again a short time later. That would not, however, have any impact on the wipers. As they're fused separately, they probably don't have a common feed, but as Vic suggests above, I suppose it's possible for them to have a common, and loose ground?
hepcat is offline   Reply With Quote
Old 09-11-2019, 09:52 PM   #4
autostaretx's Avatar
What model year?
There are slight differences in the blower speed control across the years of the T1N.
The 2003 service manual: http://www.diysprinter.co.uk/referen...e%20manual.pdf
has a different speed resistor (and splice arrangement) than the 2006: http://diysprinter.co.uk/reference/2006-VA-SM.pdf
Old 09-11-2019, 10:12 PM   #5
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Originally Posted by autostaretx View Post
What model year?
Looks to be a 2006 residing in NZ...
https://sprinter-source.com/forum/sh...51&postcount=7
Keith.
36,000 miles from New
The Following User Says Thank You to Cheyenne For This Useful Post:
lukeyt123 (10-13-2019)
Old 09-12-2019, 12:10 AM   #6
kite
My intermittent wipers don't work sometimes. I recall this could be a symptom of an issue in the steering column fuse block (intermittent connections in the board/solder joints? I think there's a post about this but I can't find it).
Last winter I left the cover off this fuse block and wiggled the relays when the wipers didn't work. This did seem to get them working...
kite is offline   Reply With Quote
Old 10-13-2019, 12:57 AM   #7
lukeyt123
What model year?
Yeah is 2006
