Old 05-01-2019, 12:45 AM   #61
Rpmextreme
Default Re: 07 Sprinter V8 LS 6.2 Conversion Engine Swap
Well the weather has been a lot nicer and we spent some time on the swap.
Engine-trans is in.
Power steering plumbed
Fuel system done
Exhaust built
Driveshaft done
Radiator done
Shifter cable done
Hit the key and she fired right up. First start video is below.
I still have to button up some wires and do some programing to get all the little things working and the warning lights off, but for a first start it has a working tach, speedo, coolant temp, PRND shift indicator and check engine light with the stock dash
Now we are getting somewhere.
http://www.rpmextreme.com/video/IMG_0906.m4v
Rpmextreme is offline   Reply With Quote
The Following 7 Users Say Thank You to Rpmextreme For This Useful Post:
Emgo (05-01-2019), hkpierce (09-19-2019), lespaint2 (07-16-2019), manwithgun (06-30-2019), Motero (05-03-2019), USMC Mustang (05-05-2019), Wheeljack (05-01-2019)
Old 05-01-2019, 05:03 PM   #62
Wheeljack
Wheeljack's Avatar
Awesome work. Well done!
https://sprinter-source.com/forum/sh...ad.php?t=78350
2010 2500 144 High Roof Cargo Weekender
The BlurrrrrMobile
Wheeljack is offline   Reply With Quote
Old 05-24-2019, 09:49 PM   #63
Rpmextreme
Here is a little update. It runs and moves under its own power. Now all we have to to is finish up all the little stuff.
http://www.rpmextreme.com/video/IMG_1275.m4v
The Following 4 Users Say Thank You to Rpmextreme For This Useful Post:
Bob Laps (05-26-2019), ClyneSnowtail (05-29-2019), lespaint2 (07-16-2019), Wheeljack (06-28-2019)
Old 06-28-2019, 06:47 AM   #64
SvenOz
Great job. How’s the last part going. Isn’t that the part where you need to work your real magic?
SvenOz is offline   Reply With Quote
Old 07-01-2019, 11:07 PM   #65
Rpmextreme
Yes. Just to find time to finish up the little things. paying jobs have to come first...... although Im ready to go drive this thing.
Old 07-02-2019, 12:49 PM   #66
Garandman
Garandman's Avatar
Is that an oil pressure light on?
2006 Sprinter 118” ~ 16” Rial Transporter rims ~ 235/65x16
Old 07-02-2019, 04:12 PM   #67
Rpmextreme
I think its the oil level light. I don't have it hooked up yet.
Old 07-15-2019, 04:40 PM   #68
turbo911
nice job. wonder what fuel mileage will be?
turbo911 is offline   Reply With Quote
Old 09-11-2019, 05:39 AM   #69
SvenOz
Yeah, paying the bills gets in the way of the real stuff, the real fun.
So, couple of thoughts and question:
Thoughts: Re Tacho, is it accurate (and tops out) or inaccurate. If the later, have you considered just replacing the dial display with a calibrated one? If the former, if, accurate and tops out, have you looked in the ECU etc settings for the Merc. I know eg they have diff ratio recorded in multiple Customer, such as for auto trans, plus ABS, plus instrument cluster. Perhaps you may be able to change the setting to appropriate needle movement for petrol, and swap the dial display? Otherwise, thought about overlay, such as a standalone Can-Bus Tacho in front, linked to the LS signal.
Question 1: Totally appreciate this is a lot of work, and no doubt, your business venture to generate income. Obviously in Aus, am not about to ship a van to you for a swap. Are yo considering any kind of 'kit' (with a premium for your profit), eg your little magic box, engine mounts, etc, just the necessary stuff. We get plenty of cheap LS engines from wrecked Commodores, and the VATS is easily disabled to make swaps easy (physically), its just the bits your working on that are needed. Any idea of pricing if you will?
Old 09-11-2019, 02:30 PM   #70
Rpmextreme
The TACH is accurate. Yes it will max out. I can get a GAS cluster from Merc with a higher TACH limit. I probably will at some point but at this time I will get everything else working first and then swap it out.
At some point I may offer it as a KIT or just electronics. We have the engine mounts, harness, computer stuff, fans, hoses, lines etc... figured out but there is a lot of other stuff that would need to be done if you are doing it yourself.... driveshafts, shifter cable, exhaust etc...
Tags
blown engine
