Go Back   Sprinter-Forum > Regional Discussions > Canada
Old 09-29-2009, 03:17 AM   #1
Daig
Default A/C off REST button
Can some one explain to me what it means when the "A/C off Rest" button light is illuminated? Not sure if it is off or on when lit?? Also, would my van be a T1N or a NCV3?
Thanks,
Daig
2007 Dodge Sprinter 2500, 170 wb, highest roof.
Daig is offline   Reply With Quote
Old 09-29-2009, 03:27 AM   #2
jdcaples
Not Suitable w/220v Gen
jdcaples's Avatar
Default Re: A/C off REST button
Thanks,
Daig
Your 2007 Sprinter is an NCV3, like mine, like Shanemac's, like BBlessing's.
When the AC Rest light is on, I believe our AC Compressor is resting, not working.
-Jon
2007 F/Liner 2500 Cargo Van, 144" WB, 3.92 Rear Axle Ratio, Buttons on the Steering Wheel, Contractor Package, Heated glass and seats, no spark plugs or windows in the cargo bay.
US Tech info: http://www.sprintertekinfo.com
US Parts info: http://epc.startekinfo.com (Subscribe to world passenger car and light transport)
Americans may learn to use MB technical resources and parts information here:
http://www.sprintertekinfo.com/epcdemo/start.swf
jdcaples is offline   Reply With Quote
Old 09-29-2009, 03:38 AM   #3
bikergar
bikergar's Avatar
Daig
Your van is a NCV3 (2007 and newer)
If the red light is on your a/c is at rest. That's how I remember it. If you push the defrost button the red goes out meaning the a/c compressor is running. If you want conditioned air push the button, light goes out, compressor starts.
A nice feature if you can remember to do it is turning the temp control all the way warm or all the way cold depending on the season, and push the a/c rest button when you exit the van (key off). The fan will come on to position 1 and will continue to run for 30 minutes or some predetermined battery voltage to pump conditioned air into the cabin in your absence. A Reilly nice feature in cold environments.
gary
Keep Doing What You Did, and You'll Keep Getting What You Got...
2008 2500 CRD 144 inch High Roof Crew Van
bikergar is offline   Reply With Quote
Old 09-29-2009, 07:31 AM   #4
mean_in_green
>1,800,000m in MB vans
mean_in_green's Avatar
I interpret the REST function to mean "free cab heat with engine off" - it only works with ignition off after all and is separate from AC. It's not a great feature though is it - the engine's radiated heat doesn't last much more than ten minutes even though the REST timer runs to thirty.
Simon, aka MIG - 416CDI (An OM651 Euro5 Panzerwagen that thinks it's a chocolate lime...)
mean_in_green is offline   Reply With Quote
Old 09-30-2009, 02:17 AM   #5
Daig
Great, thanks for the input fellas. This formum is very helpful.
