Old 04-18-2013, 07:48 PM   #11
WPJ
Default Re: Tapping into MB factory installed aux battery
I could see the draw to this as well.
1for tv and electronics,
1f fridge pump
1 for,x.....
Each one with a dedicated cut,off switch. You can run,much smaller wire to each one and save on the large costly runs or wire.
2013 2500 Passenger Wagon aka The BEAST, 144" High-top Loaded
GTA - Greater Toronto Area
WPJ is offline   Reply With Quote
Old 04-18-2013, 10:26 PM   #12
NBB
Originally Posted by Mrdi View Post
Connect to OEM Aux. Battery at this copper fuse, lower nut.(see pic)
Fuse as soon as possible after the connection.
You will find this fuse under the drivers seat, port, aft.
It has a plastic cover. (not shown)
Info and pic from MB Up-fitters document.
Don't forget to dis-connect the Aux. Batt. negative terminal
when playing up-fitter in this area.
WARNING!!
THAT IS NOT A FUSE!!
If it was, it would be a few kilo-amps, at least.
You can buy a fuse to fit into that spot.
See "My Climbing Rig", near the end.
NBB is offline   Reply With Quote
Old 04-19-2013, 02:31 AM   #13
Legwound
Originally Posted by NBB View Post
WARNING!!
I beleive you mean this thread, post 63
http://sprinter-source.com/forum/sho...limbing&page=7
Bedtime now but i'll read tomorrow, thanks for the info
Legwound is offline   Reply With Quote
Old 04-19-2013, 04:32 AM   #14
autostaretx's Avatar
I agree... it looks like the shunt for a current meter (such as a battery monitor would use to measure the current in/out of the battery).
The way those things work is that it's a carefully calibrated piece of copper, with a known (very low) resistance. Perhaps 0.001 ohm.
As (let's say) 100 amps flows through ta chunk of copper, there will be a voltage drop across it of 0.1 volts.
A sensitive voltmeter could then tell you (by seeing that tenth of a volt) that you were, indeed, drawing 100 amps.
Or, if the alternator was running (without any loads), it could also tell you how much current was crammed back into the battery.
(assuming the alternator/isolator also had to feed through that chunk of copper to reach the battery).
Old 04-19-2013, 02:18 PM   #15
afisher48
I use a Trimetric 2025 RV battery monitor on my battery system, not low cost, but I have been very happy with it. It will monitor two batteries. http://www.bogartengineering.com/products
afisher48 is offline   Reply With Quote
Old 04-19-2013, 03:48 PM   #16
NBB
No, it's not a shunt, either. It's a cheap piece of copper meant to be removed and replaced by an actual fuse. There are not any systems out there that place the shunt on the positive battery lead, anyway.
The Following 2 Users Say Thank You to NBB For This Useful Post:
autostaretx (04-19-2013), Brian12345 (01-10-2014)
Old 01-09-2014, 09:13 PM   #17
Vanwoman
This is a very helpful thread. Many thanks. Where do you hook up the negative or ground lead from an inverter if you tap in the positive under the seat?
Vanwoman is offline   Reply With Quote
The Following User Says Thank You to Vanwoman For This Useful Post:
Old 01-09-2014, 11:41 PM   #18
The PSM is for loads that use the starter battery (and/or the normal vehicle electrics).
There may well be signals you want to access (such as "engine running"), but the actual *load* for the auxiliary battery would not attach to the PSM.
In the T1N, there were *no* MB "load-side" connections on the Aux Batt... you were expected to add your own.
The attached extract from a 2007 NCV3 wiring diagram suggests that there's an "External Fuse 2" with an "uncommitted" red wire attached (lower right corner).
Look for the connection *to* "External Fuse 2" on the isolator relay.
Old 01-10-2014, 12:30 AM   #19
Mrdi
Mrdi's Avatar
Factory up-fitter manual
Mrdi
2008,2500, 144 Hi Cargo
Surf City USA,
Southern California
Mrdi is offline   Reply With Quote
The Following 8 Users Say Thank You to Mrdi For This Useful Post:
angstboater (06-26-2018), BigBlueBuilder (01-25-2017), Brian12345 (01-10-2014), hoipolloi (06-30-2016), Lilstevo (12-12-2017), michaeldorian (12-22-2015), Redskeets (11-08-2016), RoadToad (01-19-2019)
Old 01-10-2014, 01:27 AM   #20
Mrdi
Mrdi's Avatar
There are a couple of grounds under the seat as well.
Look towards the front under the seat and you will see them bolted to the floor
See #7 on page 3 on the previous posting pdf.
Mrdi
Surf City USA,
Southern California
The Following User Says Thank You to Mrdi For This Useful Post:
