No the one you get from the "Mall" is "Benz_Sprinter". If you choose "Benz", it won't have the Sprinter and they won't let you take it back.
They let you have it for 100 years.
The others are $15 a year on Android.
See this thread, post #30 and later:
https://sprinter-source.com/forum/showthread.php?t=77033&page=3
Regards,
Mark
I made this exact mistake in hast, and noticed “BENZ SPRINTER” immediately after I committed to “BENZ” for my 1 free install. Sent an email to
support@autel.com and they were able to reset my registration within 24hrs and allow me to start over.
The AP200 is proving to be a great little unit. Once BENZ SPRINTER is downloaded with the MaxiAP200 app, you will be prompted to download an additional Diag-Benz app. Owning an 07 Dodge branded sprinter, I have not had success using the auto select features that ID’s your vehicles engine and trans type. Instead, I enter the VIN @ this site:
https://carinfo.kiev.ua/cars/vin/mercedes/vin_check
which gives me the the engine and trans code to be manually selected from the Autel app. I am able to teach-in new/used DPFs and select from different methods of regeneration.
For active live monitoring of normal engine functions, you can select numeric or analog displays (and units) to view on your phone (iOS) while driving. Worth every penny so far, just takes time to establish displays and connect each time you want to view. Too much work for me to setup for every day use (as people use scangauge) but perfect for diagnostics.
EDIT: For my older iPhone, it seemed that I had to have at least 2Gs of available memory to successfully download the Autel apps and BenzSprinter data. Once installed, it takes up around 1.4G for the 3 required items.
Screenshot showing Engine Load %, Intake absolute pressure, and Fuel rail pressure.
