feynmanfan
Our goal was to deter an attempt to break into our van rather than alert when glass is broken, door compromised, etc. Our solution/approach is a bit different from others I’ve researched.
Our van has two things that makes this solution possible, WiFi and an Air Horn plus Reolink Argus 2 (wireless w/ solar panel charging) wifi cameras showing the possible entry points.
air horn
https://sprinter-source.com/forum/showthread.php?t=76464&highlight=hornblasters
camera
https://www.youtube.com/watch?v=ktbdaTslQug
If a camera “sees” a “warm body” (PIR sensor) within 10-15 feet of the van, I receive an alert on my phone. I can look at the live stream to see if “he/she/it” look suspicious or if one if the cameras was disabled. Granted, 99% will be curious people, animals, etc., but if warranted I can send a signal to sound the Air Horn. The horn is controlled by a wifi “inching relay” (parallels the horn button) that “makes” for ½ second. I can resend/honk repeatedly if they linger but suspect one 150db honk will do the trick.
wifi relay (EWeLink app screen shot attached)
https://www.amazon.com/gp/product/B077Z5B461/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
If we are away from the van; hiking (as long as my phone/van has a 4G signal) we are covered. The PIR sensor can be disabled (via app) during the day if false alerts become an annoyance. I assume most bad things happen at night, and false alerts at night should not be a problem.
Oh, and if you are a thief and reading this for scouting/nefarious reasons, we also have a 60 lb "good boy" who travels with us and sleeps in the van. If you make it into the van, the air horn will be the least of your problems.
air horn
camera
